Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
  1. #16
    Oct 2004
    Southern Highlands NSW
    1,898
    Different qualities to the swarf seems like a handy way to differentiate between brass and bronze.
  2. #17
    7,188
    I haven’t turned a lot of bronze but somewhere have a bag full of Phosphor Bronze curlies after turning down a bunch of bushes. Haven’t seen anything like this with brass. Cu is completely different as it tends to gall.
  3. #18
    34
    1,079
    Brass can be made to chip with ground carbide inserts for ally and an aggressive feed rate, it's quite satisfying
  4. #19
    Boringgeoff is offline Try not to be late, but never be early.
    Apr 2011
    Bakers Hill WA
    75
    43
    Default Very light yellowish
    Hi all,
    I've read this thread and decided to tack my query on here in the hope that my problem will be solved. Attached are two photos of the dismantled chuck/ ratchet housing of a Tough Major brace.
    #1 is in daylight without flash, #2 is using flash. The greeny yellow stripe is the reflection of my hi-vis jumper. I've filed the plating (Nickel?) off and in #1 you can just make out the remains of the round steel pin which was the ratchet selector retainer. The metal is very pale yellow, non-magnetic and I'm leaning towards White Bronze but I need an expert opinion.
    I'm in the process of writing an article about Tough braces and need to get my facts right when I say what the housing is made of.
    Geoff.
  5. #20
    Dec 2005
    South Australia
    1,657
    Elan tell me more about these inserts
  6. #21
    34
    1,079
    They're CCGT; polished on top, ground sides, very high positive rake https://www.iscar.com/eCatalog/Famil...geType=4&rel=T
    Perfect for anything soft; ally, brass, plastic, etc.
  7. #22
    Dec 2005
    South Australia
    1,657
    Thanks Elan, looks like they are not what I want.
  8. #23
    34
    1,079
    What do you want to do? There might be another alternative
  9. #24
    Dec 2005
    South Australia
    1,657
    I am intending to purchase one of these 10 mm (I have a small lathe) https://www.lprtoolmakers.com.au/car...s-free-insert/
    first job will be boring brass, tips it comes with are not suited to brass so I am looking for suitable tips.
  10. #25
    34
    1,079
    TCGT tips of the proper size will do the trick; same thing, just triangles
  11. #26
    Dec 2005
    South Australia
    1,657
    Thanks Elan, I will look it up
  1. Replies: 8
    Last Post: 28th Aug 2019, 10:12 AM
  2. Metals grades and uses
    By Gaza58 in forum METALWORK GENERAL
    Last Post: 23rd Mar 2019, 06:37 PM
  3. Identifying metals
    By terry arnold in forum METALWORK GENERAL
    Last Post: 24th Jun 2009, 05:23 AM
  4. Different metals and a different finish
    By Grahame Collins in forum METALWORK GENERAL
    Last Post: 1st Aug 2007, 07:09 PM
  5. metals sales...
    By Toolin Around in forum METALWORK GENERAL
    Last Post: 26th May 2007, 11:34 PM
