Results 16 to 26 of 26
Thread: Yellow(ish) metals?
8th Mar 2020, 08:11 AM #16Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
Different qualities to the swarf seems like a handy way to differentiate between brass and bronze.
8th Mar 2020, 09:54 AM #17Member: Blue and white apron brigade
- 7,183
I haven’t turned a lot of bronze but somewhere have a bag full of Phosphor Bronze curlies after turning down a bunch of bushes. Haven’t seen anything like this with brass. Cu is completely different as it tends to gall.
8th Mar 2020, 10:01 AM #18Gear expert in training
- 34
- 1,075
Brass can be made to chip with ground carbide inserts for ally and an aggressive feed rate, it's quite satisfying
24th Jun 2020, 11:46 AM #19Try not to be late, but never be early.
- Apr 2011
- Bakers Hill WA
- 75
- 43
Very light yellowish
Hi all,
I've read this thread and decided to tack my query on here in the hope that my problem will be solved. Attached are two photos of the dismantled chuck/ ratchet housing of a Tough Major brace.
#1 is in daylight without flash, #2 is using flash. The greeny yellow stripe is the reflection of my hi-vis jumper. I've filed the plating (Nickel?) off and in #1 you can just make out the remains of the round steel pin which was the ratchet selector retainer. The metal is very pale yellow, non-magnetic and I'm leaning towards White Bronze but I need an expert opinion.
I'm in the process of writing an article about Tough braces and need to get my facts right when I say what the housing is made of.
Geoff.
27th Jun 2020, 12:07 AM #20China
- Dec 2005
- South Australia
- 1,656
Elan tell me more about these inserts
27th Jun 2020, 07:16 PM #21Gear expert in training
- 34
- 1,075
They're CCGT; polished on top, ground sides, very high positive rake https://www.iscar.com/eCatalog/Famil...geType=4&rel=T
Perfect for anything soft; ally, brass, plastic, etc.
27th Jun 2020, 11:48 PM #22China
- Dec 2005
- South Australia
- 1,656
Thanks Elan, looks like they are not what I want.
28th Jun 2020, 10:20 AM #23Gear expert in training
- 34
- 1,075
What do you want to do? There might be another alternative
28th Jun 2020, 04:41 PM #24China
- Dec 2005
- South Australia
- 1,656
I am intending to purchase one of these 10 mm (I have a small lathe) https://www.lprtoolmakers.com.au/car...s-free-insert/
first job will be boring brass, tips it comes with are not suited to brass so I am looking for suitable tips.
28th Jun 2020, 04:46 PM #25Gear expert in training
- 34
- 1,075
TCGT tips of the proper size will do the trick; same thing, just triangles
29th Jun 2020, 01:38 AM #26China
- Dec 2005
- South Australia
- 1,656
Thanks Elan, I will look it up
McMaster-Carr Reusable Peel-Away Coating for Metal, Transparent Yellow
By Cueball in forum METALWORK GENERALReplies: 8Last Post: 28th Aug 2019, 10:12 AM -
Metals grades and uses
By Gaza58 in forum METALWORK GENERALReplies: 1Last Post: 23rd Mar 2019, 06:37 PM -
Identifying metals
By terry arnold in forum METALWORK GENERALReplies: 3Last Post: 24th Jun 2009, 05:23 AM -
Different metals and a different finish
By Grahame Collins in forum METALWORK GENERALReplies: 22Last Post: 1st Aug 2007, 07:09 PM -
metals sales...
By Toolin Around in forum METALWORK GENERALReplies: 20Last Post: 26th May 2007, 11:34 PM
