Results 1 to 9 of 9
    Feb 2012
    Tamworth, NSW
    205
    Default Boring bar threading?
    As a complete beginner when it comes to insert tooling I have what I think will be a silly question! I have a very nice little boring bar and I wonder if I can use a 60deg threading insert mounted on the bar for external thread cutting? My chuck is held on by studs and I would like to try threading in reverse away from the head stock like I know several members here have done. I have attached some pics on the boring bar I have - is there a way to use it as a threading tool as well or is it only to be used for internal boring?
    etched on the tool are the following - SR34-514 WX**0403 A10K-SWLXR04-D120
    if I can’t use this one is there a preferred threading insert holder and inserts anyone can recommend?
    Aug 2011
    4,779
    Hi there,
    I have a couple of threading insert holders (inside & external threading) and both 55 and 60 degree indexed threading inserts.
    I got them from eBay for probably $20 each. They work pretty good. I now only use hss for threading to a tight shoulder etc.
    Im not sure if the threading inserts will fit that boring bar but for the price of 1 boring and couple of inserts, just buy one!
    34
    1,079
    Quote Originally Posted by Danger Mouse View Post
    Short answer: No.
    The main reason being that your boring bar does not take actually triangular inserts (which is the shape of threading inserts), but what's called a Trigon shape; which has an included angle of 80 degrees, not 60. Triangular inserts will not seat properly.
    Nov 2017
    Geelong, Australia
    57
    2,665
    I think the tool holder you need for reverse external threading of RH threads is a SEL tool holder, and IR inserts, eg SEL1212H16 and 16IR AG60 inserts.
    The 16IR will cut metric 0.5-3.0mm pitches.
    Feb 2012
    Tamworth, NSW
    205
    Thank you everyone - that has really cleared it up for me. I’ll go and see what I can grab on eBay.
    Ian
    Oct 2010
    melbourne, laverton
    1,910
    I like your thinking.
    I know i try and i wish you could use 1 tool for every thing.
    imagine that. Use your toaster to paint your walls,jump start your car as well as shave...
    6,473
    Hi Ian, Guys,
    This is the shape of the boring bar and insert. You can get very close to the work with these. That tip point is about a MM away from the flat surface. I'm about to cut the thread for the elephants foot for a dial gauge.
    Feb 2012
    Tamworth, NSW
    205
    Thanks Baron
    Looks exactly like what I am after. Does this use the inserts Steve mention in his post above?
    Ian
    6,473
    Hi Ian,
    Yes it does ! I have both 55 and 60 degree inserts for mine. It came from "Banggood" very cheap, about £6 or £7 UK post free, complete with 3 inserts.
    I also bought a bar that holds the same inserts but is intended to go straight in like a normal lathe tool.
  1. Threading bit.
    By BaronJ in forum METALWORK GENERAL
    Last Post: 20th Jul 2019, 09:30 PM
  2. Replies: 5
    Last Post: 11th Sep 2015, 07:22 AM
  3. need help with threading
    By justron in forum METALWORK GENERAL
    Last Post: 2nd Sep 2014, 11:04 PM
  4. Threading again
    Last Post: 10th Dec 2011, 03:16 PM
  5. SOLD: 50mm-mt3 shank precision boring head & boring bar kit
    By SurfinNev in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 15th Jul 2010, 02:42 PM
