Results 16 to 28 of 28
24th Feb 2020, 12:29 AM #16Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
24th Feb 2020, 06:00 PM #17Most Valued Member
- 2,651
WD40 has a very poor rust preventative action - pretty much anything else is better!
Lanox is great stuff, but in my experience you end up with a slightly sticky surface after its been there for a while.
I've been using a 50/50 blend of Acetone and ATF as a general penetrant mix and usually have a trigger bottle of it handy, so generally anything that needs a bit of rust preventative cops a squirt of that. Its the ATF that does the protecting - the acetone is just a carrier. Only downside is ATF stinks - but it works well and the price is right. Seems to last pretty well.
24th Feb 2020, 07:40 PM #18Most Valued Member
- Oct 2010
- 1,910
24th Feb 2020, 07:54 PM #19Most Valued Member
- 2,651
New oil, just cheap dextron 3 type oil as it’s what I had lying around. It separates from the acetone, but a quick shake gets it mixed again.
25th Feb 2020, 05:27 PM #20Senior Member
- Apr 2018
- 168
After sandblasting or electrolysis with oxylic or citric acid to remove rust from old tools, I spray them with silicon dry lube and just let them sit until it has dried. lasts for years.
26th Feb 2020, 05:16 PM #21Most Valued Member
- Oct 2010
- 1,910
I saw a russian engineer. in mexico. clean up a heap of rusty tools . sockets ect in a pot of river sand vibrated on a upturned orbital sander.
It worked great.
26th Feb 2020, 07:02 PM #22Member: Blue and white apron brigade
- 7,183
26th Feb 2020, 08:51 PM #23Mechanical Butcher
- Oct 2004
- Southern Highlands NSW
- 1,894
26th Feb 2020, 10:59 PM #24Member: Blue and white apron brigade
- 7,183
SWMBO has a Lot-O-tumbler, a vibratory rock tumbling machine for polishing rocks and glass. It's a 150 mm diameter, thick round rubber container with a hole in the top that sits in a steel frame that is attached to an off centre motor that vibrates the bejesus out of whatever is in the container. The vibrations create this continuous swirling roil of the contents. Depending on what size grit is used it can round over rocks through to polish them to a decent finish. It's VERY quick compared to a standard rotary tumbler. She hardly ever uses it - maybe that would be worth a go?
27th Feb 2020, 05:24 PM #25Intermediate Member
- Dec 2015
- 42
- 31
I actually have a Lyman 1200 Pro Turbo Tumbler for cleaning rifle cases ... but the media is reasonably expensive and I'm not clean on contaminating it with rust and oil. Vibratory tumblers do work brilliantly though.
Your Lot-O Tumbler looks pretty heavy duty by comparison. Makes sense given I rarely want to "round over" my rifle cases
27th Feb 2020, 06:49 PM #26Most Valued Member
- Oct 2010
- 1,910
ha that looks like it. what i saw was a Russian/mexican dockside version of that.
aaron
27th Feb 2020, 06:55 PM #27Member: Blue and white apron brigade
- 7,183
The lotto tumbler works with a wide range of weird polishing materials. I’ve even heard of some one using used coffee grounds which we have plenty of at our place as we go through about 3kg of coffee a month. Keeping the grounds from going mould is on the challenging side, maybe putting the straight into a sealed container is worth a try.
27th Feb 2020, 08:04 PM #28
My wife and I don't drink much coffee nowadays, in fact she doesn't drink tea or coffee at all !
In the days that we did, she used to put the grounds in a biscuit tin and after finishing her baking, roasting or whatever, put the biscuit tin in the oven while it cooled. The net result was dry cakes of material that she mixed with compost and used to plant her seeds and bulbs in pots. It never went mouldy ! In fact on occasions there was a nice coffee odor in the kitchen.Best Regards:
Molasses rust removal
By morrisman in forum AUTO RESTORATIONReplies: 6Last Post: 1st Jan 2017, 07:45 PM -
Black rust & molasses
By georgedgerton in forum METALWORK GENERALReplies: 2Last Post: 26th Nov 2015, 11:30 AM -
HIGH TENSILE BOLTS Vs MILD BOLTS.
By chambezio in forum METALWORK GENERALReplies: 13Last Post: 3rd Jan 2014, 08:25 PM -
welding flash
By mid life crisis in forum WELDINGReplies: 4Last Post: 23rd Jun 2012, 09:29 PM -
Preventing rust on welded zincalume or galvanized steel?
By Mathuranatha in forum WELDINGReplies: 9Last Post: 2nd Jul 2009, 11:12 AM
