Results 1 to 10 of 10
20th Feb 2020, 07:43 AM #1Philomath in training
- 6,540
Mill table width information needed
I'm trying to design up a device* to fit on a mill table. My mill is larger than most home mills with a table width of 235mm, so I'm not sure it is the best thing to base a design around. I would like to know what others have got. If you can respond with
- table width
- T-slot width
- T-slot centres
That would help me understand what is out there.
As per the rotary table sizing rule, I don't want to be specifiying a base size that overhangs enough to reduce travel.
*Encouraged by the success of the free vice, I'm trying to knock a few more projects off the 'if only I had something that would hold this' list. This is to make work holding easier for me on those odd occasions but if I'm going to have parts cast, I may as well make them so that they have wide utility.
20th Feb 2020, 08:37 AM #2Most Valued Member
- 4,887
Hello Michael,
My table sizes are,
Width 240 mm
Centres 45 mm
Tee slot width 15 mm
5 Tee slots
Width 210 mm
Centres 45 mm
Tee slot width 16 mm
4 Tee slots
20th Feb 2020, 08:57 AM #3
Michael take a look at specs on such as H&F site the variety of sizes is amazing.
20th Feb 2020, 09:15 AM #4Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,536
My RF 45 is 730x210, 4 slots on 50mm centres, nuts are 14mm wide.
The RF 30 round column I moved on had the same table, and I believe the RF 46 also shares the same table.
20th Feb 2020, 06:07 PM #5Philomath in training
- 6,540
That's the problem - if I worked on the full range of equipment available then I could have anywhere from a table 150mm wide to 400 or perhaps even 600mm. At least doing things this way gives me a chance of working out what the common sizes are.
Right now with 2 data points (3 if you include me) it is shaping up that 200mm is a nice number
20th Feb 2020, 08:55 PM #6Most Valued Member
- 2,651
Width 235
Tee slots 12.7
Centers 54
3 slots
20th Feb 2020, 09:35 PM #7Most Valued Member
- 5,942
X2 Mini mill table width 93mm, 3 T slots, 12mm wide with no mention of their centres.
21st Feb 2020, 11:08 AM #8Most Valued Member
Hi Michael,
My two mills have the following;
ZAY 7045 (common 45 size Chinese geared head mill):
table width: 240mm
T slot size: 15.8mm (5/8")
Spacing 60mm x 3 slots
Pacific FTV-2 (AKA Lagun FTV-2):
table width: 230
T slot size: 16mm
Hope this helps...
21st Feb 2020, 12:35 PM #9Member
- Oct 2012
- Mullaloo WA
- 80
Mill Table Width
Hi Michael
My Taiwanese Bridgeport type Mill, Branded Delta has the following sizes
Table. 254mm
T slot Width. 15.9mm
T slot Centres. 63.5mm
Hope this helps
Kind regards
Col
21st Feb 2020, 03:52 PM #10Most Valued Member
How to zero a universal mill table?
By Pete O in forum METALWORK GENERALReplies: 14Last Post: 15th Oct 2018, 08:53 AM -
Information needed on Empha E30 mill
By Michael G in forum METALWORK GENERALReplies: 0Last Post: 17th Jan 2013, 06:45 AM -
mill table
By morrisman in forum METALWORK GENERALReplies: 21Last Post: 12th Jan 2013, 11:42 AM -
Rambaudi Mill Information
By dreinoga in forum METALWORK GENERALReplies: 3Last Post: 2nd Mar 2011, 10:25 AM -
Which rotary table for your X2 Mill
By Big Shed in forum METALWORK GENERALReplies: 3Last Post: 1st Oct 2009, 08:39 AM
