Results 1 to 5 of 5
Thread: H59 brass
    Jul 2008
    near Warragul, Victoria
    3,718
    Default H59 brass
    I need to machine some 8mm brass rod . It's a carby throttle shaft . I am milling a section down to 4mm thick for the butterfly . What would be the most suitable milling cutter for a nice clean finish ?
    6,444
    Hi Morrisman,
    If it were me I would be using a straight sided woodwork router bit ! Straight sides and no rake, run it fast and take fine light cuts so that you don't bend it. Or drill a suitable hole in a block of hardwood to support the shaft whilst machining.
    Edited to add, you could use the same support to cut the slit for the butterfly !
    Jul 2008
    3,718
    Default Thanks
    Thanks baron
    The butterfly is fixed by two 3-48 screws
    6,444
    Hi Morrisman,
    After you have slit the rod put a piece of scrap brass plate in the slot and then drill and thread as needed.
    Just leave the bar in the jig.
    34
    1,075
    Fyi, all woodwork bits have a positive cutting angle
  1. what rods for thin brass to brass ??
    By Mathuranatha in forum WELDING
    Last Post: 23rd Nov 2020, 08:17 PM
  2. VICTORIA Brass Flat Bar Assorted Sizes & 1/4" SWB Threaded Rod & 260 Carbide Brass Sheet
    By thumbsucker in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 18th Mar 2013, 03:36 PM
  3. 5/16 Brass
    By rogerbaker in forum METALWORK GENERAL
    Last Post: 11th Nov 2012, 10:57 PM
  4. Brass on Brass
    By funkychicken in forum METALWORK GENERAL
    Last Post: 24th Mar 2009, 09:50 PM
  5. brass
    By weisyboy in forum METALWORK GENERAL
    Last Post: 15th Jun 2008, 09:23 PM
