Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: Bs-5s
  1. #16
    Sep 2004
    Dardanup W.A.
    72
    331
    Quote Originally Posted by Ray-s View Post
    I just checked mine (B5-5S about 2 years old) and as Bob has indicated it looks like there is a spacer on that end - see item 24 on the parts list below (that isn't drawn to scale going by mine).
    Happy to take any measurements, pull things apart etc that might help you.
    Thanks Ray, much appreciated.
    I have got spacer fitted to the main pivot shaft now.
    and also spaced the motor back by 1 nut width, which gives clearance when vertical.
    While I had the motor off, I replaced the two bolts that the motor pivots on with a length of all-thread, which has made the motor mount very rigid now, ...it used to be very floppy before.
    Ray, does your vice deck stop short of the blade by 30mm (ish) or is it closer, and also, does your saw provide any support for work-pieces beyond the blade? (see my pics above in previous post)
  2. #17
    Sep 2004
    Dardanup W.A.
    72
    331
    Quote Originally Posted by Flo View Post
    I have the same bandsaw and it exhibits the same characteristics as you mention.. I also find it hard to get it to make a straight cut..
    Flo
    I spent some time setting the guide wheels up to get the blade dead square, so I will see how it cuts in the horizontal position once I organise some way to hold the short lengths & need to cut.
  3. #18
    6,475
    Hi Phill,
    Quote Originally Posted by ptrott View Post
    Oh how lucky you are to have a gap John,....all I have is an angled drop-off to the base of the saw, and to top it off, the blade is 30mm from the edge of the vice.
    Not a lot of thought went into this, so I will have to not only extend the jaws, I will also have to fabricate a solid base at the same level as the vice base.
    Attachment 384760Attachment 384761
    That is one big gap ! I would be making a steel block to go under the blade and as wide as the vise. I would screw it through the base to secure it. Without support at that point from the vise bottom to a little beyond the blade, you cannot cut a thin slice. I extended the vice jaws right up to the blade. Within a few mm. But make sure that the blade is cutting straight first. If the blade starts to run off it will catch the edge of the new jaw plates. An early warning system that the bade pressure is too heavy or is wearing out.
  4. #19
    6,475
    Phill, just a thought is there any advantage in putting that spacer at the other end of the hinge pin ?
  5. #20
    Tennant Creek, Aust
    61
    601
    Just read this and had a quick look at mine.
    Mine is 4 or years old,
  6. #21
    Feb 2014
    Werribee, Melbourne
    178
    The blade on mine is 25mm from the moving jaw of the vice (over as far as the as supplied slot allows) and 18mm from the fixed jaw.
    I notice that your pivot shaft is a hair below the surface of the casting with the spacer in place - that is very slightly proud on mine so you might have lost a few mm with the thickness of that spacer?
    My normal mode of use is for cutting pipe & bar stock but have had to muck around holding smaller bits on occasion.
    Mine is exactly as yours with no outboard underneath support.
    On a positive note, I did as you and checked the guide bearing adjustment pretty carefully and for my backyard hobby use it is streets ahead of of what I used to do with a hacksaw.
  7. #22
    Sep 2004
    Dardanup W.A.
    72
    331
    No can do, because when it gets to near vertical, it kicks a few mm to the side for some reason.
  8. #23
    Sep 2004
    Dardanup W.A.
    72
    331
    I notice that your pivot shaft is a hair below the surface of the casting with the spacer in place - that is very slightly proud on mine so you might have list a few mm with the thickness of that spacer?
    I have just finished cutting the flat bar for the extended jaws, and happy to say that the cuts are dead square and straight as an arrow
    Very poor design in not having any form of outboard support. I will have to fashion one to attach to the base casting a.s.a.p.
    Is there any way to knurl faces of the extended jaws something like a set of vice jaws, or is not necessary?
  9. #24
    Sep 2004
    Dardanup W.A.
    72
    331
    Quote Originally Posted by wm460 View Post
    I can't tell from that photo if there is a spacer or not, my eyes are not what they used to be
  10. #25
    Feb 2013
    Laidley, SE Qld
    1,039
    Your eyes are ok, my spacer is very skinny, maybe 2mm wall, I had to vernier the shaft and the spacer to check that there was a spacer.
  11. #26
    6,475
    Hi Phill, Bob, Guys,
    I wouldn't bother trying to pattern the vise jaws. Mine are smooth ! If any friction was needed a piece of emery cloth placed between the work piece and the fixed jaw would work.
    From looking at the pictures of the hinge in the various posts from different machines, there seems to be a wide variation in hinge widths ! Poor design, poor manufacture, poor quality control as has been alluded to.
    Whilst when I bought mine, I knew from the outset that it required work doing on it, the multitude of modifications required to actually get a machine that worked properly as intended was unexpected.
  12. #27
    Sep 2004
    Dardanup W.A.
    72
    331
    The issue of a total lack of "outboard" support on this particular bandsaw design has now been addressed.
    Length of 50mm X 10mm flat bar, two 30mm lengths of M6 high tensile all-thread, and 4 nuts.
  13. #28
    Sep 2004
    Dardanup W.A.
    72
    331
    Passed the acid test with flying colours
