Results 1 to 7 of 7
Thread: bandsaw speed
15th Feb 2020, 08:25 PM #1Senior Member
- Apr 2014
- 134
bandsaw speed
hi
is 1300 fpm to fast to cut aluminium on a bandsaw
cheers steve
15th Feb 2020, 09:20 PM #2Senior Member
- Oct 2015
- melbourne
- 473
Charts seem to say 600-1000fpm
I've seen 50mm Al cut with a normal circular saw...which could be up to 10000fpm.
Might depend on the thickness and teeth/inch of the blade.
15th Feb 2020, 09:34 PM #3Gear expert in training
- 34
- 1,080
I've cut ally on a woodworking bandsaw, not sure how fast it was going, but definitely faster than any metal bandsaw.
15th Feb 2020, 10:09 PM #4
I've got a 10" inch chop saw that runs at 2800 rpm that is specifically intended for aluminium and has a cutting capacity of 100 mm square. I also cut 20 mm thick aluminium sheet on the vertical wood bandsaw without too much trouble.
You do need to be aware that depending upon the size of material you are cutting, it can get very hot quite quickly.Best Regards:
15th Feb 2020, 10:38 PM #5Member: Blue and white apron brigade
Depends on the thickness.
I regularly cut 6 mm Al on a 3000 fpm WW bandsaw.
I use a wax lube - ie ores the was onto the cut line and sometimes onto the blade.
Cutting thicker than this at this speed can start to gall in the cut.
1000 fpm should be OK
With the tables I cut up to 30 mm thick but I do use a composite blade - negative kerf teeth.
With a WW blade it is possible for the saw to grab the work and tear out teeth.
The teeth go flying off around the workshop like little bullets and the tables saw bucks around across the floor due to unbalanced blade.
16th Feb 2020, 06:07 AM #6
Hi Bob, Guys,
My chop saw came supplied with all HSS blades ! Its only later that I fitted a TCT blade. The original wax lubrication doesn't work very well with the TCT one, the blade doesn't get hot enough to keep the wax liquid, so I use a WD40 spray can.Best Regards:
16th Feb 2020, 03:54 PM #7Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,196
High Speed No.O ???
By Anorak Bob in forum THE HERCUS AREAReplies: 2Last Post: 8th Jun 2019, 10:19 PM -
Bandsaw blade speed.
By BaronJ in forum METALWORK GENERALReplies: 15Last Post: 2nd Feb 2018, 11:43 PM -
Wood Cutting bandsaw speed - budget workaround
By steamingbill in forum METALWORK GENERALReplies: 0Last Post: 25th Mar 2016, 02:54 PM -
Variable Lathe spindle speed control project for constant surface speed
By jhovel in forum METALWORK GENERALReplies: 27Last Post: 15th Oct 2014, 08:34 AM -
The Need for Speed
By Anorak Bob in forum METALWORK GENERALReplies: 4Last Post: 27th Jan 2011, 02:10 PM
