Results 1 to 15 of 15
11th Feb 2020, 10:08 PM #1Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,552
Anyone want to grind a cutter for me?
I have a tapered cutter on what I believe is an MT3 shank I’d like touched up.
Anyone have a T&C grinder, the skills and the motivation to assist?
Don’t mind paying return postage if you’re interstate, and certainly don’t expect a freebie (happy to work out a deal, whether liquid currency or legal tender is up to you).
I don’t have a T&C grinder (or the space for one) or the necessary understanding required to use one
If you are interested and want to have a crack, feel free to message me.
Also not averse to taking it to a commercial outfit if anyone has any suggestions on where to take it in Adelaide.
11th Feb 2020, 10:12 PM #2Most Valued Member
- Jul 2016
- 35
- 1,522
Do you want to use that as an actual countersink? It would only be good for drilling type ops.
11th Feb 2020, 10:18 PM #3
Hi Racingtadpole, Guys,
I might be wrong, but that looks like it might be an awkward cutter to regrind.
What is its application ?Best Regards:
11th Feb 2020, 10:26 PM #4Most Valued Member
- Mar 2011
- 1,552
Yes I want to use it to cut tapers into holes, I don’t think it’s been taught any other tricks at this point.
Not prepared to disclose the actual application at this point because if it works I will be looking to commercialise the product. At the moment it’s purely experimental. I could cut the taper on the lathe, but work holding is a bit more challenging.
11th Feb 2020, 10:30 PM #5
Hi Racingtadpole,
In that case it would be more cost effective to buy a countersink bit. Or if you have any carbide woodwork router bits, use one of them. They work very well as you have probably seen from some of my pictures.Best Regards:
11th Feb 2020, 10:41 PM #6Gear expert in training
- 34
- 1,079
What's the included angle? I suspect finding a carbide bit that matches (or is near enough) would be both easier and cheaper than trying to sharpen that. Carbitool have a 60 degree https://www.carbitool.com.au/product...solid-carbide/
Also, is it just the camera playing tricks or are the flutes not actually straight? Cos that'd be a right pain to even think about
11th Feb 2020, 10:45 PM #7Most Valued Member
- Mar 2011
- 1,552
The Pilot hole will be somewhere in the vicinity of 22-25mm, I’ve not seen a router bit that big.
Yeah it’s semi helical, no trick photography. The cutting head is about 50mm across at its widest, and about 16mm at its smallest so a router bit is nowhere near big enough.
11th Feb 2020, 10:58 PM #8
Hi Racingtadpole,
Ouch, that is a big cutter, the one in the picture doesn't look that big. Those teeth look to have a double angle on them.
I've just been and looked at my router bit set ! My biggest cutter is a 40 mm diameter 45 degree angle one, it is about 10 mm diameter at the small end.
Are you actually wanting to cut a taper or just deburr ? Also if you are wanting to cut a taper, what angle are you looking for ?Last edited by BaronJ; 11th Feb 2020 at 11:03 PM. Reason: Added Questions!
11th Feb 2020, 11:01 PM #9Most Valued Member
Does it need to be that particular shape? I have a couple of round over router bits that are approx 25mm radius (from memory), if they're of any help?
12th Feb 2020, 12:27 AM #10China
- Dec 2005
- South Australia
- 1,657
Complete saw works lonsdale 8297 6366
Without exception the best sharpening service in South Australia
12th Feb 2020, 07:30 AM #11Philomath in training
- 6,559
Not what you asked for, but I have a Tree boring head that is capable of boring a tapered hole. If you just need one or two done as prototypes I could help that way.
12th Feb 2020, 09:01 AM #12Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
What type of material do you intend to cut with it? It looks like it might have been made as a trade or tech school project and may only be case hardened mild steel.
12th Feb 2020, 01:55 PM #13Most Valued Member
- Mar 2011
- 1,552
The small end is 16mm, large end is 52, I’ll work out the angle later when I’m not on a bus. Despite it being semi helical the flutes appear to be flat ground as evidenced by the cutting grind becoming larger at the point of rotation around the axis. There may well be some merit in the suggestion that it was an apprentice project, I don’t know it’s history, it came to me as part of a job lot from a deceased estate.
My widget needs to be made from steel as it is a wear part of sorts. I may make the prototype out of ally though for no other reason than I have some in about the right size.
Even if I don’t wind up using it for this particular job a sharp cutter is a useful cutter, not so much if it’s blunt...
China, thanks Lonsdale is a 3 water bag trip, but I might try the saw doctor at Pooraka. Never even thought twice about connecting sharpening rotary lawnmower blades with milling cutters. If I don’t have any luck there I’ll give your suggested company a call
Michael, thanks for the offer, I may well be in touch
12th Feb 2020, 02:38 PM #14Golden Member
- Dec 2011
- 505
Another option?
These "Taper drills" may be of interest: from https://mcjing.com.au, who do seem to keep some uncommon items.
I have no connection with the supplier other than as an occasional customer.
The shank sizes seem a bit spindly particularly on the larger cutters, but that could be addressed.
I do have one of those on the list - a 36-50mm taper drill acquired for a project, as a blank for re-sharpening to a custom shape.
However the cutter remains unaltered and unused, sleeping in a drawer.
Cheers, Bill
12th Feb 2020, 02:49 PM #15Most Valued Member
- Mar 2011
- 1,552
That certainly may be another option, thanks
An axe to grind
By sossity in forum JEWELLERYReplies: 6Last Post: 24th Dec 2019, 12:48 PM -
How to grind this threading tool?
By jack620 in forum METALWORK GENERALReplies: 12Last Post: 17th Apr 2019, 09:10 AM -
Lathe tool holder too thick - can I grind it down?
By jabell in forum METALWORK GENERALReplies: 8Last Post: 24th Nov 2014, 09:14 PM -
Can someone grind a MT1 taper on a threaded rod for me.
By Sturdee in forum METALWORK GENERALReplies: 7Last Post: 27th Apr 2013, 09:49 AM -
need somewhere to surface grind some pbar stock??
By holmsy2000 in forum METALWORK GENERALReplies: 2Last Post: 13th May 2007, 12:03 PM
