Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
  1. #16
    6,475
    Hi Joe, Guys,
    Perhaps dipping it into a bucket of hydrochloric acid or some other strong acid might dissolve the corrosion and leave the two metals untouched?
    I think this is a bad Idea ! The hydrochloric acid will attack and damage both metals.
  2. #17
    Jul 2006
    Athelstone, SA 5076
    4,258
    I have oxy & acet. Can bring it up. wont take to long to try and see if works.
  3. #18
    Jun 2012
    SA
    1,649
    I would also go the heat route, but be VERY careful temp wise as brass will melt/deform easily.
    You can see where the brass has been spread though earlier pressing/hammering efforts, so it's basically made the situation worse.
    The end game will probably be to cut/drill one side and crack/spread it with a cold chisel. That will open the centre enough to remove the brass. Then it's a simple matter to grind and fillet weld the slot.
    Cheers Rob
    The worst that can happen is you will fail.
    But at least you tried.
  4. #19
    Adelaide
    68
    1,374
    Default Success!
    Thanks to all for the suggestions, we attacked it with heat today and followed that up with "enthusiastic percussive maintenance" - i.e. a big hammer - and it finally came out after 50 or more years.
    This is the valve core and handle after separation and cleanup.
    And this is the handle installed on the
    replacement valve.To get an idea of the sizes, the flange is 6" in diameter.
    Interestingly, looking at mating surfaces there is no sign of corrosion - it's possible that the handle was heat shrunk onto the spindle, although why they would have done so is a mystery, especially as there's a ¼" retaining split pin.
    Thanks again for the suggestions, it reflects the value of these forums.
  5. #20
    Mar 2014
    South of Adelaide
    1,227
    i would try some heat on the opposite side from the handle, use a 15 or 20 tip in the oxy, heat it up quick. It does look a little like the end of the shaft is peened, if heat doesn't work you may have to cut the handle off. if you are just trying to get the handle off to fit to another valve you may be better off just making a replica for the other valve. what is the valve off? my guess is something broad gauge SAR
  6. #21
    Adelaide
    68
    1,374
    It's all good, the handle came off.
    Spot on. Replacement tender for Rx class loco
  7. #22
    Oct 2010
    melbourne, laverton
    1,910
    good one mate. what is the tank for?
  8. #23
    Adelaide
    68
    1,374
    Quote Originally Posted by azzrock View Post
    It's a replacement for a heritage loco tender.
  9. #24
    May 2011
    Murray Bridge S Aust.
    5,959
    Makes the 4" grinder look very small.
  10. #25
    Oct 2010
    melbourne, laverton
    1,910
    Quote Originally Posted by Gavin Newman View Post
    nice work what does a loco tender do? carry fuel or something?
    aaron
  11. #26
    Adelaide
    68
    1,374
    aaron
    In this case, around 7 tons of coal and 3,500 gallons of water.
  12. #27
    Oct 2010
    melbourne, laverton
    1,910
    Steam trains cool. did Steam trains ever use diesel like some steam ships?
  13. #28
    Dec 2005
    South Australia
    1,657
    Wash your mouth out!
  14. #29
    Adelaide
    68
    1,374
    Some do burn heavy oil, not diesel, and a few burn wood but the bulk use coal. The Victorian Goldfields locos burn oil but all the SA preserved locos use coal.
    Some locos were converted back and forth between the 2 fuels in their day but that's a compromise as the fireboxes really need to be different to get the best from each type of fuel.
  1. Gas safety valve??
    By creesy in forum WELDING
    Last Post: 22nd Jun 2019, 06:10 PM
  2. OT Valve grinding paste
    By bob ward in forum METALWORK GENERAL
    Last Post: 10th Jun 2018, 02:36 PM
  3. valve seats
    By morrisman in forum AUTO RESTORATION
    Last Post: 16th Jul 2017, 07:56 PM
  4. valve guides
    Last Post: 13th May 2017, 06:13 PM
  5. Compressor Non-return Valve
    By electrosteam in forum METALWORK GENERAL
    Last Post: 6th Jun 2014, 11:45 AM
