Results 1 to 7 of 7
Thread: ali plate
    Apr 2014
    134
    Default ali plate
    hi
    any perth members know where to buy aluminium plate offcuts 10/12mm thick
    cheers steve
    Jul 2007
    332
    Steve, you could try Robert Cameron & Co in Burswood, near the casino, usually has offcuts, price tends to be higher end. No connection, Alan.
    Mar 2011
    Southern Flinders Ranges
    1,552
    Capral here in Adelaide usually have small pieces out for sale at reasonable prices, left overs from commercial supply where they cut to order, or the straight and flat bits off the ones that didn’t fare so well in transit. Maybe check out one of their branches. A 300x300 plate of 12mm in 6061 T6 normally sells out of the oddments area here for $25 to give you an idea of price.
    7,188
    Capral in Canning Vale or Welshpool occasionally have off cuts. A few years ago they would also guillotine 1.2m long strips of a larger sheet of 10mm but >12 mm had to be Cnc router cut so a minimum set up and cutting fee of $70 applied. What specific size are you after?
    Apr 2014
    134
    Default ali plate
    thanks bob and to the other replys no specific sizes
    steve
    6,473
    Hi Steve,
    Quote Originally Posted by shaper07 View Post
    steve
    In that case I would be hunting around scrap yards ! Also you might find that engineering places will happily sell you their scrap or even give you bits of it.
    May 2010
    135
    I get various sizes/ offcuts from the local boat building place in Mandurah when I'm in that part of the woods. They eyeball whatever I pull out of the scrap bin, and charge me based on their calibrated eyeball judgement of weight, and the "near enough" scrap value.
    Thinnest is around 2-3mm, thickest has exceeded 20mm (but it's rare to find stuff thicker than 12mm as common in the bin)
    Des
  1. Bronze plate
    By PDW in forum WANTED TO BUY
    Last Post: 31st Dec 2018, 08:27 AM
  2. Plate rolling
    By KBs PensNmore in forum METALWORK GENERAL
    Last Post: 14th Dec 2018, 01:52 AM
  3. face plate
    By shaper07 in forum THE HERCUS AREA
    Last Post: 13th Nov 2017, 09:54 PM
  4. Compact Workpiece Clamps for the face plate and angle plate.
    By metaler in forum METALWORK PROJECTS
    Last Post: 10th Oct 2016, 07:16 AM
  5. angle plate???
    By turbo TA in forum METALWORK GENERAL
    Last Post: 25th Apr 2010, 09:17 PM
