Results 1 to 15 of 24
4th Feb 2020, 09:08 PM #1Member
- Apr 2013
- Canberra
- 54
Where to get toolmaker vice holddowns?
I bought a toolmaker vice from Hare and Forbes... had a voucher, wanted one! I stupidly assumed a vice would come with hold downs, but it has not. Now looking it seems they're not a straight forward purchase item. Can anyone tell me where I can purchase a set? Any help greatly appreciated.
4th Feb 2020, 09:44 PM #2Most Valued Member
- 4,890
You will probably have to make your own or have someone make them to suit your vice and the item they are clamping too.
4th Feb 2020, 10:34 PM #3Member
- Apr 2013
- Canberra
- 54
4th Feb 2020, 11:31 PM #4Golden Member
- Mar 2009
- 54
- 825
G'day Matt,
I've never understood why they don't come with the vice when they put the slots there for them.
Something like these might be worth a try and they can be used to clamp things directly to the table as well:
https://www.ebay.com.au/itm/T-SLOT-T...843ee351d1c133
Greg.
4th Feb 2020, 11:36 PM #5
Read the post here and then seen you asked on a FB page as well.
For a supplier to add hold downs to be suited to every mill T slot size on the market would be hard.
I haven't seen them commercially available, but I think they would be available somewhere.
For the price they would charge you with postage you would be better off making them yourself.
Do you have another vice to make them with? Or a lathe and a drill press/hand drill?Using Tapatalk
4th Feb 2020, 11:42 PM #6
5th Feb 2020, 01:03 AM #7Most Valued Member
5th Feb 2020, 03:27 AM #8
Hello Matt,
I can't remember if I posted pictures of mine here or not, anyway I can't find them.
I made them from some scrap 7/8" inch square bar, cut to length with an 1/8" slice cut off underneath leaving a raised edge about an 1/8" inch wide and then milled off the top so that they fit into the slot. I drilled mine to take M6 cap screws.It took a couple of hours to make them.
If you need I can go take some more pictures later.
I have my vise mounted on a reference plate held down to the mill table by a couple of clamps. The vise itself is clamped by four hold downs. You can see two of them right at the bottom of this picture.Best Regards:
5th Feb 2020, 05:43 AM #9Member
- Apr 2013
- Canberra
- 54
Thanks Dave,
Figured I cast a wide net and see what I catch!
I have the tools to make some hold downs, it just seems bizarre they don’t come with some. Even if they just had a pilot hole that you drilled out to suit your t-slots would make more sense than a vice that isn’t particularly useful until you make tooling to hold it.
Matt
5th Feb 2020, 05:45 AM #10Member
- Apr 2013
- Canberra
- 54
5th Feb 2020, 06:33 AM #11Senior Member
- Perth, Western Australia
- 67
- 362
5th Feb 2020, 09:26 AM #12Member
- Apr 2013
- Canberra
- 54
It’s a fair point, guess I’m just surprised. Looks like I’ll be making some. I should be pleased for a new project but I had plans that now need to go on hold until I do.
The only square stock I have is Damascus too, so they’re gonna be fancy ones
5th Feb 2020, 09:44 AM #13Senior Member
- May 2010
- 135
5th Feb 2020, 01:30 PM #14Member
- Sep 2010
- Port Sorell, Tasmania
- 74
Am in a similar situation, have been able to clamp the vice to the table with 4 regular hold down clamps but it looks messy. Picked up a couple of clamps similar to the ebay specials in #4 above but they were way too big. Will make something, a nice little beginners project. Was thinking of using 4140, does that sound reasonable.
Tony
5th Feb 2020, 02:50 PM #15China
- Dec 2005
- South Australia
- 1,658
It is like when you a lighting fixture, many times they don't come with any sort of bulb
carter no 4 vice , pipe vice,triton saw holder
By robyn2839 in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 27th Nov 2018, 04:27 PM -
Thoughts on these Toolmaker vices?
By Com_VC in forum METALWORK GENERALReplies: 22Last Post: 28th Mar 2018, 10:24 AM -
1957 CVA Toolmaker Lathe
By KBs PensNmore in forum METALWORK GENERALReplies: 6Last Post: 13th May 2017, 01:23 PM -
SOLD: Deckel FP1 universal toolmaker's milling machine
By Greg Q in forum METALWORK - Machinery, Equipment, MARKETReplies: 8Last Post: 28th Aug 2013, 02:16 PM -
Sale of Deceased Toolmaker tools
By Big Shed in forum METALWORK GENERALReplies: 1Last Post: 13th Oct 2011, 10:35 AM
