Results 1 to 7 of 7
Thread: Holding workpiece for milling
3rd Feb 2020, 07:28 PM #1
First up, I have not as yet done any milling, but will soon be on a vertical milling slide on my lathe.
The pieces I want to mill will be 85mm square by 52.5mm thick.
The milling will be performed across the 52.5mm face, so the face of the piece will be standing 85mm out from the face of the slide.
As yet I have no way of holding these, so before I drop $$$$s, I want to know if a precision milling machine vice (Precision tool vices QKG80_Machine Tool Access._M&G Productions) would be suitable, or is there a better option?
I will be making 6 of these, so need to have something that works, but doesn't cost me a kidney, and will be useful in the future for other projects. (Versatile)
3rd Feb 2020, 07:51 PM #2Philomath in training
- 6,540
In theory yes, but at 7kg is going to be mighty heavy. I would also check what size it is. Most vertical slides for lathes are not all that wide, so it may not fit.
You might be better mounting an angle on the slide and then clamping the blocks to the angle, either with G clamps or another angle on the other side and some all-thread or something clamping the two bits together (if you did it that way you could clamp the second angle down to the slide too, to give further support).
3rd Feb 2020, 08:00 PM #3Member: Blue and white apron brigade
- 7,182
I don't think a vice will be as important of an issue as the other sliding components on the lathe. You will have to make sure there's no slop on this - maybe even tighten them up a bit for the job?
3rd Feb 2020, 08:12 PM #4
The slide is 125 X 100.
The weight is an unknown quantity, because the same seller quotes the same vice as 5.5kg on his ebay listing.
I could go for the next size down (Precision tool vices QKG73_Machine Tool Access._M&G Productions) which is 4.1kg.
The angle iron idea might work too, thanks.
3rd Feb 2020, 08:14 PM #5
3rd Feb 2020, 08:26 PM #6Senior Member
- Jun 2012
- melbourne
- 341
Is your lathe quite rigid? I made a vertical milling slide based on the H&F one. I deliberately put a lot of weight into the adapter plate, about 30Kg of steel. The adapter itself was dead rigid and solid. I tried a small cut and gave myself a fright and immediately made plans to buy a 1.5 ton milling machine.
With the amount of stickout from the saddle, you are putting a lot of leverage. My lathe was a 300mm x 1000mm chinese one. I'd say the best you could hope for is very light cuts and you need to make sure the cutting is pushing down on the toolpost cos lathes aren't too good on force pushing upwards (well mine anyway).
I had read how light mills can only do light cuts and never thought it would a problem. In reality, I couldn't live with less than my heavy mill. Its scary when milling and things go wrong. Be careful and good luck. If its just pasltic or maybe aluminium, you might be ok.
Avoid climb milling at all costs.Last edited by sossity; 3rd Feb 2020 at 08:29 PM. Reason: Added the last bit.
3rd Feb 2020, 09:13 PM #7
Reasonably rigid but who knows if sufficient until tried.
On the shopping list I have made for when the lotto win comes through
I can set the slide towards the centre of the cross slide if that would help
There will be no up or down machining, the direction will be front to back, and only 53mm of travel. There will be no toolpost involved, just the slide bolted to the cross slide, perhaps via a solid block to raise it up closer to the centreline.
Indeed, no climb milling
Swiveling stool that douples as a long workpiece support too.
By Tuomas Soikkeli in forum METALWORK PROJECTSReplies: 0Last Post: 11th Apr 2019, 09:11 PM -
Work Holding Clamps
By metaler in forum METALWORK GENERALReplies: 1Last Post: 11th Dec 2016, 12:31 PM -
Compact Workpiece Clamps for the face plate and angle plate.
By metaler in forum METALWORK PROJECTSReplies: 0Last Post: 10th Oct 2016, 07:16 AM -
Holding down a lathe
By mav_walrus in forum METALWORK GENERALReplies: 7Last Post: 8th Jul 2015, 01:28 PM -
Maximum workpiece weight for a 260 lathe
By boilermaker8 in forum THE HERCUS AREAReplies: 3Last Post: 30th Jul 2013, 10:53 AM
