Results 31 to 45 of 55
5th Feb 2020, 11:12 AM #31Most Valued Member
- 4,890
I have a 127 plate I could of hired but it suits an 8 & 10.
5th Feb 2020, 11:16 AM #32Golden Member
- Sep 2009
- 666
Oh that’s very kind of you but I’m keen to have a crack at making the plate myself I think. Then I’ll have a blank plate I can make new hole patterns on if I ever need it.
Gives me a chance to try coordinating the drilling of 127 holes with the degrees, minutes, seconds. Will be fun.... or very frustrating
5th Feb 2020, 11:27 AM #33Most Valued Member
- Jul 2016
- 35
- 1,522
The problem you will have with making your own isn't in the making, but in verifying it's accuracy
5th Feb 2020, 11:41 AM #34Golden Member
- Sep 2009
- 666
5th Feb 2020, 12:56 PM #35Most Valued Member
Thread cutting and pitch consistency will be the indicator.
Although if your only cutting short threads and your not planning on cutting any leadscrews on your lathe then it will probably be fine.
7th Feb 2020, 07:42 AM #36Golden Member
- Sep 2009
- 666
Can I test my maths for creating a 127 hole dividing plate on a 90:1 rotary table?
90/127 = 0.708661417323 = 0* 42’ 31.18”
So the order would be:
0* 42’ 31.18”
1* 25’ 2.36”
2* 7’ 33.54”
2* 50’ 4.72”
etc, etc
7th Feb 2020, 08:14 AM #37Most Valued Member
- 4,890
You would need to divide 360 by 127 then convert that too degrees minutes seconds,
( 2.8346 = 2 50' 4.56" ) and a plate of around 200 mm OD.
7th Feb 2020, 02:06 PM #38Golden Member
- Sep 2009
- 666
22nd Feb 2020, 10:42 AM #39Golden Member
- Sep 2009
- 666
What would you choose? Milling machine mods
The rotary table arrived. Amazing service as it was here in about 4 days I think! Unfortunately that’s where the good news stopped.
When it arrived I couldn’t get the handle to move separate to the gear engagement mechanism. Rather than force it I thought I’d strip it all down anyway to clean the sticky grease off.
Turns out it had been poorly treated in transit. The table gear and spindle where damaged from what appears to be a drop.
The spindle was locked because of the fragments of the gear and the spindle was bent.
Luckily the vendor has been very accommodating and given I have it completely stripped anyway, they’re sending replacement parts for me to assemble myself. Just need to figure out a way to align the gear with the table.
24th Feb 2020, 09:18 PM #40Golden Member
- Sep 2009
- 666
Seller had a replacement gear and spindle shipped express. Landed today. Spent this evening trying to get my head around how to put it all together again.
Took my time to dial in all the adjusters to get the least amount of play. Was able to remove almost all of the play in the spindle as well as dial in the backlash down to nearly nothing. Will get a dial indicator on it at some point to get it down to a couple of the tenths.
For a “not expensive” option, I have to say I’m impressed. The action is buttery smooth and you can really dial it in. It’s all cleaned and lubed and ready to be used in anger.
Also had a play with the dividing plates. Again it’s buttery smooth and seems super easy to use. Can’t wait to have to use that either.
2nd Mar 2020, 11:06 AM #41Senior Member
- Dec 2009
- 134
Which seller is that from? Always good to keep good sellers on the list.
2nd Mar 2020, 12:14 PM #42Golden Member
- Sep 2009
- 666
Zeal tools. Shipping was exceptional, communication was great and resolution was swift. Table is great too.
10th Jun 2020, 10:38 AM #43Golden Member
- Sep 2009
- 666
Minor update. Will be pulling the trigger on a DRO this week
Going 3 axis and will try and figure out a way to connect the quill to the third axis and ideally a gas strut to stop the tool dropping which is very annoying.
Appreciate any input/ideas on how to achieve this on an RF-30 mill.
28th Jun 2020, 07:26 PM #44Golden Member
- Sep 2009
- 666
Today was the first time I’ve properly used a DRO and those that recommended it are right; it’s an amazing/essential but of kit for the mill.
My install has been relatively standard. Drilled, tapped and mounted the x axis on the rear of the table:
Yes I’ve lost 19mm of Y travel, but I’ve never used anywhere close to all the travel anyway.
The Y was a little more complicated. I only wanted the scales to move, not the reader heads, so I didn’t have cables moving all over the place.
To achieve this I made a bracket for the table with cutouts for the dovetails. This extended down and provided the surface to bolt the scale Alu mounting bar to:
I really love this little mill, it’s really turning out to be one of the best things I out in the shed (alongside the lathe and TIG).
The Z is going to take a bit more time to sort out. I don’t want it hanging off the side of the quill and I want to keep the depth stop too. So my thought is to build something to mount it off the back of the quill stop mount and put it up inside the mill (so it’s hidden):
Here’s my contraption to make it all work:
The blue tube will be cut to make L brackets (pretty heavy wall tube and I hope it will be strong enough). That’s a linear bearing to create the sliding surface for the top of the scale.
The bit I made this afternoon was the metal bracket on the bearing block. It bolts to the block and creates a central bolt point for the top of the scale.
Using my new centre finder I was easily able locate the centre of my part and navigate the 16mm and 15mm coordinates with ease. I was even able to go back and hit the coordinates again to countersink the bolt heads with absolute precision. Love it!
A very simple part, but was a breeze to make:
28th Jun 2020, 08:07 PM #45Golden Member
- Apr 2018
- Drouin Vic
- 634
Agree the DRO revolutionises use of the mill, like a QTCP does for the lathe. Being able to do the same operation in multiple locations, knowing you can easily come back for subsequent operations, as opposed to multiple tool changes at each location is one of my favourite things about the DRO.
Noticed your comment about a gas strut to prevent the tool dropping- there should be a tension adjustment on the quill clock spring which is located under the cap on the left of the mill. Not sure how yours is adjusted, but this is there for that purpose.
Nice work on the installation BTW- especially the tricky Y axis.
Milling Machine
By CAC221 in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 6th Feb 2018, 12:57 PM -
Help me choose a MIG
By joez in forum WELDINGReplies: 4Last Post: 16th Jan 2017, 07:39 PM -
which lathe should you choose , one out of the two linked inside?
By thorens in forum METALWORK GENERALReplies: 18Last Post: 16th Jul 2013, 12:20 PM -
A little help with my first milling machine
By festy_ in forum METALWORK GENERALReplies: 36Last Post: 13th Apr 2011, 11:34 PM -
Milling Machine
By R W in forum METALWORK GENERALReplies: 7Last Post: 17th Mar 2011, 09:02 PM
