Results 16 to 30 of 55
2nd Feb 2020, 10:07 PM #16Golden Member
- Cairns, Q
- 666
I don't have a DRO, and would like one eventually, but of the various accessories I do have, it is the H/V rotary table with the dividing plates which wins on all points.
Some of the jobs which it has done would have been difficult or more complex without it (or in some cases a dividing head) were:
Making additional lathe change gears, including a 47T/37T compound gear to allow the lathe to cut metric threads
Drilling bolt hole circles in new back plates for the chuck mounting bolts (easy if you already have a DRO though)
Drilling tommy bar holes in a 5MT ER32 chuck to stop it rotating while the nut is being tightened
Making a 50 mm diameter four lobed dog clutch for the Blanchard lathe
Making the actuating plate for the half nuts on the Blanchard lathe. This has two opposite short curved slots on
different centres from the centre pivot. Pins on the half nuts, which project through vertical
slots in the saddle and through into the curved slots in the actuating plate, are forced to move vertically as the
plate is rotated, opening and closing the half nuts.
Making hexagons on custom brass pipe fittings and adapters, and custom bolts and nuts to match missing ones on old cars
and machinery (before I got ER32 collet blocks)
Making centres for bicycle sprockets to use on a slow speed light load application - much cheaper than buying industrial
sprockets and chains
Graduating collars for feed screws
Etc
Etc
Frank.
2nd Feb 2020, 10:44 PM #17Golden Member
- Sep 2009
- 666
I’m warming to the idea of a Rotary Table with dividing plates. I’ll mostly be doing rotary work and occasionally having a crack at gears, so it seems like the right tool for the job.
Seems to be a bit more expensive than a Dividing Head but with a 90:1 worm gear ratio I’m sure I could do some custom dividing plates for things like a metric transposing gear for my lathe (127 tooth).
3rd Feb 2020, 07:05 AM #18Philomath in training
- 6,563
A dividing head is not 100% interchangable with a rotary table -
You won't get 127T from a semi-universal dividing head or rotary table as it is one of those awkward prime numbers that they can not cope with. You either need a special dividing plate or a dividing head capable of differential indexing (big $$$)
3rd Feb 2020, 07:31 AM #19Golden Member
- Sep 2009
- 666
What would you choose? Milling machine mods
Ah fair enough on the 127 gear. Clearly there expensive for that reason.
I’m pretty sold on the Rotary Table but the DRO is looking like a solid next upgrade. Will have to save my pennies.
Looking at bolt hole functions on DRO’s, is that something that could drive the coordinates of a 127 hole pattern?
3rd Feb 2020, 08:18 AM #20Most Valued Member
- Jul 2016
- 35
- 1,522
Some drops can do linear grids of holes, but it's really simple to just make a spreadsheet of the coordinates and hit them manually
3rd Feb 2020, 08:34 AM #21Golden Member
- Sep 2009
- 666
3rd Feb 2020, 08:51 AM #22Most Valued Member
I don't think that there would be many DRO's that would allow you to enter 127 for the number of holes..
I just looked at an app on my phone but it only allows up to 35.
Manually entering on a RT would be hit and miss. Don't forget you would need to convert from degree decimal to mins and sec of arc. Doing that 127 times would be a pretty good feat, probably not impossible though.
3rd Feb 2020, 09:13 AM #23Most Valued Member
- Jul 2016
- 35
- 1,522
I had a cheap Chinese DRO that would allow up to 250 holes, my Newall does not have a limit but has trouble finding the next point if you put heaps of holes on a tiny PCD.
What I meant before was some Gros can lay out a grid of hole s, say you wanted a 20 * 20 grid with 25mm spacing it would just take you from one to the next.
3rd Feb 2020, 10:21 AM #24Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,039
For general mill work I would go for the DRO, you don't need an expensive one, even a 2 axis DRO will improve your productivity dramatically.
The DRO can replace one typical use of the rotary table, which is to drill bolt circles.
I've been using a cheap DRO from AliExpress on my lathe (replacement for the original Easson) for the last 3 or 4 years without problems.
There are old threads on here about low cost DROs.
3rd Feb 2020, 11:07 AM #25Golden Member
- Cairns, Q
- 666
neevo,
Here is the table of available divisions for the Vertex HV6 rotary table with the standard dividing plates: from memory I think the HV8 and HV10 have a few less gaps in the available divisions. Remember though that as the size goes up so does the weight. Even the HV6 with a 6" 4 jaw chuck attached is surprisingly heavy.
Simon,
Quote: Manually entering on a RT would be hit and miss. Don't forget you would need to convert from degree decimal to mins and sec of arc. Doing that 127 times
I had to do this with one of my 37/47 metric conversion gears which could not be cut using the dividing plates - think it was the 47T one. As you suggest, it is very slow and very prone to errors. It did work first time though, and the gear runs smoothly and quietly with the original change gears, so it is feasible at least with low speed lightly loaded gears. I would not have liked doing it 127 times though - 47 was quite enough thank you!
Frank.
4th Feb 2020, 11:29 AM #26Golden Member
- Cairns, Q
- 666
neevo,
Sorry, I missed this post earlier. No, you don't have to approximate them by eye, and yes, Simon is correct: you do have to work in degrees, minutes and seconds of arc. There is a vernier scale on the wheel which rotates the table which is graduated in, I think without checking, ten seconds of arc divisions. These graduations are widely spaced, so it is possible to split them into quarters by eye and get close to an average of about two and a half seconds of arc, a very small error for something like a low speed lightly loaded lathe change gear. It is a slow and tedious job, but quite feasible.
Frank.
4th Feb 2020, 01:02 PM #27Golden Member
- Sep 2009
- 666
I did a bit more reading. I didn’t realise the level of accuracy you can get to on a Rotary Table.
127 looks easy if/once you get the coordinates for 127 holes!
5th Feb 2020, 08:46 AM #28Golden Member
- Sep 2009
- 666
Rotary Table has been acquired. Already investigating 3 axis DRO’s
5th Feb 2020, 11:06 AM #29Most Valued Member
- 4,890
What size table did you purchase?
5th Feb 2020, 11:07 AM #30Golden Member
- Sep 2009
- 666
Milling Machine
By CAC221 in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 6th Feb 2018, 12:57 PM -
Help me choose a MIG
By joez in forum WELDINGReplies: 4Last Post: 16th Jan 2017, 07:39 PM -
which lathe should you choose , one out of the two linked inside?
By thorens in forum METALWORK GENERALReplies: 18Last Post: 16th Jul 2013, 12:20 PM -
A little help with my first milling machine
By festy_ in forum METALWORK GENERALReplies: 36Last Post: 13th Apr 2011, 11:34 PM -
Milling Machine
By R W in forum METALWORK GENERALReplies: 7Last Post: 17th Mar 2011, 09:02 PM
