Results 16 to 30 of 42
Thread: tslot sizing
23rd Jan 2020, 12:14 AM #16
Using Tapatalk
23rd Jan 2020, 06:47 AM #17Most Valued Member
That's pretty cool Dave.
The number of times I've had to undo a clamp to slide another in after already starting a process....
28th Jan 2020, 01:10 PM #18Senior Member
- Nov 2012
- Mid North Coast NSW
- 423
28th Jan 2020, 01:51 PM #19Most Valued Member
- 2,672
They're mobile numbers - just look strange if you're not used to dealing with full IDD codes.
Just drop the +0061- on the front and add a zero
The second number is definitely the correct one for Alex who looked after me last time I was out there. 0430083332
I'll comment that it's currently Chinese New Year, so while I'd expect them to still be around there's a pretty good chance they're affected in some form.
You'd be best sending Alex a text on that number and go from there. I'm happy to drop over and pick a few things up and post to if its easier. PM me if you want and we can sort it out.
Not trying to push you into buying from them, but happy to help make it work if you do.
28th Jan 2020, 02:07 PM #20Senior Member
- Nov 2012
- 423
Ah ok thanks for that.
I just noticed google reckons they're closed today, open tomorrow, so I'll just try them tomorrow.
oh and you might be able to answer this, they have slot drills but appear to be Weldon shaft. I've not seen them before, can they be used in an er32 collet or would that damage the collet ?
28th Jan 2020, 04:02 PM #21Most Valued Member
- 2,672
No personal experience with Weldon shanks in collets, but a quick search online turned up "works fine" with an unconfirmed caveat that you lose about 30% holding power on the collet.
29th Jan 2020, 11:40 AM #22Senior Member
- Nov 2012
- 423
He saw my number come up on his phone and rang me back.
Will be putting in an order today for :
Clamping kit to suit 15.8mm Tee slot (M14)_Machine Tool Access._M&G Productions
1"x2"x3"Block Set within .0002"_Machine Tool Access._M&G Productions
10 Pairs in 1/8" set Steel Parallels_Machine Tool Access._M&G Productions
Telescoping Gage 6 PCS set: 5/16" to 6"/12.7mm to 150mm_Measuring Instrument_M&G Productions
HSS Cobalt 8% DIN 844 end mills with center cut,weldon shank,Dia 20x20x38x104x4T_Cutting Tools_M&G Productions
29th Jan 2020, 12:04 PM #23Most Valued Member
- 2,672
Good to hear.
Did you discuss postage cost? I know that's been a topic of discontent from some members but I've always picked up so not sure how they actually charge these days.
I'll hassle him about the image and listing for those cutters as its very misleading showing a picture of a set of cutters and a 1.5kg weight for just one cutter.
Please report back how you get on and what you think of the stuff when it arrives.
29th Jan 2020, 12:42 PM #24Senior Member
- Nov 2012
- 423
Yeah he said post should be around $30 for the lot. He said to just put in an order and not pay and they will send an invoice.
They definitely need to do something about their website. Wrong photos, no descriptions, fix phone numbers etc,,so yeah get stuck into them.
I would have liked to grab a large 2 flute slot drill in carbide but they're a little beyond my budget at the moment.
29th Jan 2020, 06:43 PM #25Senior Member
- Nov 2012
- 423
Holy hell !!!
Just got the invoice....they want $50 freight...that's Vic to Mid north coast NSW.
29th Jan 2020, 07:03 PM #26Most Valued Member
- 4,890
That's not to bad.
29th Jan 2020, 07:35 PM #27
I agree, look at the weight and compare it on aus post site.
Then there is packing material, time to pack it etc.
Compare just the clamp set with H&F including postage, I'm sure just that one thing will easily show you a massive saving.
I couldn't believe how cheap there tooling was when I looked earlier following your links, thanks.
I always wanted a Australian company with cheap tooling like the USA guys have, I think I just found it and will be buying through them in the future.Using Tapatalk
29th Jan 2020, 07:40 PM #28
H&F $110 and $17.90 postage to my address for a M14 clamp set.
Using Tapatalk
29th Jan 2020, 08:10 PM #29Senior Member
- Nov 2012
- 423
Yep..I just tried that with H&F too. I set it for delivery from Vic and got $17.90.
Seems to me if you add a few small items that $30 would be fair.
Notice H&F says it's 8.5KG, M&G productions calls it 14KG.
I did put the order in but I can't say I'm too happy with the freight cost.
At least overall the cost is still cheaper than elsewhere.
29th Jan 2020, 09:10 PM #30
Belt sizing???
By KBs PensNmore in forum METALWORK GENERALReplies: 15Last Post: 28th Apr 2019, 07:33 PM -
Lathe chuck sizing
By simonl in forum METALWORK GENERALReplies: 4Last Post: 5th Jul 2018, 06:54 PM -
Need help sizing railing rods
By AllStarMe441 in forum METALWORK GENERALReplies: 9Last Post: 12th Dec 2015, 11:08 AM -
transformer sizing for 480v VFD
By oreos40 in forum METALWORK GENERALReplies: 10Last Post: 18th Sep 2012, 05:10 AM -
re-sizing pics
By brendan stemp in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 13Last Post: 17th Dec 2010, 11:54 PM
