Results 1 to 11 of 11
    Jan 2017
    Rubyvale Qld Australia
    60
    35
    Default What can I use as a cutting fluid.
    I need to cut 10 of the 16, 22 & 32mm holes into 3mm SHS using annular cutting bits and the only business in our small town that sell this kind of cutting oil is completely out.
    I'd like to do this job tomorrow and am wondering what other products could I use to help the annular cutting bits last longer.
    Aug 2006
    1,106
    I wouldn't even bother if you are only cutting into 3mm thickness.
    Aug 2006
    1,106
    Just use some cutting compound such as trefolex if you must.
    May 2011
    Murray Bridge S Aust.
    5,956
    We use ordinary coolant mixed with water for our annular cutters, when the machine is being used upside down on 3-4mm RHS we don't use any as it won't flow upside down and can't be bothered putting on a longer tube. If you'r really worried about it, use some CRC/WD40 and the likes, or as ComVC puts it any cutting compound will do.
    You'll probably find that it won't get hot enough to be of any major concern, on that thickness anyway.
    6,471
    In the absence of anything else, lard, ideally mixed with a bit of sulphur ! Just brush it on the face of the cutter.
    Quote Originally Posted by Specialized29er View Post
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    I cut some 2.5mm thick RHS today with a 16mm version and it was fine dry. If you want to be nice to it, I would suggest some WD40 or similar in a spray bottle / can.
    Oct 2015
    melbourne
    473
    I'd just use ordinary engine oil.
    Is that bad?
    Aug 2011
    Perth, Western Australia
    67
    362
    Quote Originally Posted by russ57 View Post
    Is that bad?
    I do too.
    I mix in some WD or CRC to thin it a bit.
    Tony
    6,471
    The idea behind using something like lard is that it melts easily and is sticky, so it tends to cling to a surface. Adding sulphur or similar improves the lubricating properties. Temaxol is of this ilk !
    Mar 2011
    Southern Flinders Ranges
    1,552
    In a former life I did add/move/change work on communication towers. Used to drill a lot of 18 and 26mm holes (M16 and M24 bolts) for splice plates, guy take offs and mounting corsets in everything from 8mm angle iron to 30mm plate, all were drilled dry. Didn’t seem to make much difference to cutter life if we used fluid or not, and not using it meant one less thing to take up.
    Nov 2010
    Gippsland Victoria
    733
    Default Cutting Oils
    I've had the impression for a while now that the subject of cutting oil for us hobbyists is a bit like oils for the lathes ways.
    ie. Any oil is better than no oil. I've used cheap olive oil from Woollies at times on my lathe.
    In Sparey's book he talks about using whale oil, other old books talk about using lard as suggested in a post above, somewhere else I found somebody's recipe for stuff he called "angels breath" (= 1 part turps : 2 parts white spirit : 3 parts olive oil) I've seen people recommending Automatic Transmission Fluid in other forums.
    ....... and yes before somebody jumps in, I'm sure that scientifically formulated manufactured cutting oil could be best of all, but if you've gotta do it now and don't have any Tap Magic or Trefolex or Rocol or Venom or Whateverite in the shed then its fine to try some of whatever is available in the "car fluids box" or in the kitchen cupboard.
    Bill
  1. Alternative To WD-40 Sought For Aluminium Cutting Fluid.
    Last Post: 18th Jun 2016, 03:09 PM
  2. welding & cutting fluid
    By meadow street in forum WELDING
    Last Post: 31st Jan 2015, 04:49 PM
  3. Modified coolant/cutting fluid
    By Ben Dono in forum METALWORK GENERAL
    Last Post: 23rd Apr 2014, 10:38 AM
  4. Cutting Fluid Ratio
    By Kidbee in forum METALWORK GENERAL
    Last Post: 26th Aug 2013, 11:52 PM
  5. HAFCO Cutting/Coolant Fluid
    By Plushy in forum METALWORK GENERAL
    Last Post: 7th May 2010, 01:51 PM
