Results 1 to 11 of 11
    Nov 2018
    Tasmania
    97
    Default Surface Grinder Travel Less than Mag Chuck
    I've recently picked up a Kent KGS-200 Surface grinder
    I need to resurface the mag chuck, but I had a look and the chuck is slightly longer than the overall table travel.
    This will mean I get high points at each end. Not ideal
    Unless anyone's got a better idea, I'm thinking of repositioning the chuck on the table so I can fully traverse to one end, grind that end slightly lower than required. Then shift the chuck and do the same at the other end.
    After this I would recentre the chuck and surface the now full traversable surface between the ends.
    Any better ideas?
    Sep 2014
    Elimbah Qld
    24
    If the chuck is longer than the travel I'd under cut the back only first then move the chuck so the full travel is achieved an able to put a fence up at the front that isn't under cut
    Aug 2011
    4,779
    What Steve said sounds like a plan. Another plan would be to sell this chuck and purchase another one that is suitable for your grinder.
    Also, dont forget that the idea of dressing the surface of the chuck also allows (to a certain extent) for any fluxtuations in the surface that the mag chuck sits on, which also should be dressed. If you are moving your mag chuck to areas on the table that cannot and have never been dressed, then you will introduce other flatness issues that will be introduced on the surface of your mag chuck.
    Having a mag chuck that is larger than the work envelope of your SG would be a right PITA.
    6,439
    Is there a travel stop at the ends that can be temporarily removed ?
    Nov 2018
    Tasmania
    97
    No unfortunately, it's fully reaching the end of the table travel and bottoming out on the castings
    The scary part is the table actually rides up about 3mm at one end if I fully let the castings collide
    So I will need to have a stop at that end before I have a wheel explode or similar
    Nov 2018
    Tasmania
    97
    Quote Originally Posted by stevejw66 View Post
    Yeah I'm liking the idea of a single move to get it right
    Not quite sure what you mean by a fence though?
    6,439
    Hi Tommy,
    A fence is simply a raised edge to stop the work piece from being pushed off the end of the magnetic chuck.
    Often there is one on the far edge as well.
    If you look at these pictures you can see two fences. The long one held by two screws and a small one screwed on at the end. The sole purpose is to position the work piece and stop it being pushed off the end.
    Nov 2018
    Tasmania
    97
    Hi Tommy,
    Ok I was a bit confused, I've only ever seen a fence at the back side. One on the side could be a nice feature to have
    Nov 2018
    Tasmania
    97
    Well tonight a decided to tackle this
    I shifted the chuck so I could fully reach the right end and I ground the first 30 mm of that end low by 0.3 mm
    I then readjusted the chuck so I could traverse between the low spot and the other end and cleaned up the surface
    It turned out ok, although with a little bit of chatter (maybe wheel balance?)
    I don't think the chatter will be a problem for accuracy (I can't measure it), but I might dust it off for cosmetic purposes
    I don't think I ever want to wet grind again! What a mess
    6,439
    Hi Tommy,
    Yes you can see the chatter marking ! That wheel probably needs balancing and dressing.
    Aug 2011
    4,779
    Hi there,
    Dressing your grinding wheel should get most of that out. Balancing may help. I run 250mm wheels on my Elliot SG and I have never balanced them (purely because I don't have the setup to do it) but I do dress them as required.
  1. Surface Grinder or T&G Grinder, which is best for adapting?
    By TommyGMachining in forum METALWORK GENERAL
    Last Post: 18th Jun 2019, 09:13 AM
  2. Surface grinder help
    By DSEL74 in forum THE SMITHY
    Last Post: 2nd Mar 2017, 10:29 PM
  3. Surface Grinder Magnetic Chuck - Remagnetise
    By electrosteam in forum METALWORK GENERAL
    Last Post: 15th Jan 2017, 09:27 PM
  4. surface grinder
    By allterrain50 in forum METALWORK GENERAL
    Last Post: 27th Apr 2014, 04:06 PM
  5. surface grinder
    By China in forum METALWORK GENERAL
    Last Post: 19th Feb 2008, 12:48 AM
