Results 1 to 8 of 8
Thread: Drawbar Removal Tool
4th Jan 2020, 01:23 PM #1Most Valued Member
- 5,942
Got this in an email and thought it might be of interest to some of the members on here.
Ever been in the situation of putting the drawbar spanner down to pick up the hammer to knock out the drawbar, then realise it needs to be undone a bit more, but then can't find the spanner. Well, this could be your answer
https://www.homemadetools.net/forum/milling-machine-spanmer-draw-rod-removing-tool-77152?utm_source=newsletter&utm_medi
HTH.
4th Jan 2020, 08:45 PM #2
Hi Kryn, Guys,
I recall seeing that idea on some forum years ago ! Indeed there was a commercial product available as well.Best Regards:
4th Jan 2020, 11:56 PM #3Gear expert in training
- 34
- 1,075
Hammer? I just give the bar a knock with the spanner
5th Jan 2020, 11:10 PM #4Senior Member
- Victoria, Australia
- 114
These days I use my 18v Makita impact driver to loosen and tighten the drawbar. Then the small steel mallet.
6th Jan 2020, 10:32 PM #5Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 831
I gave up manually loosening and tightening the drawbar on my old vertical milling machine years ago, now I just push a couple of buttons for 8 second tool changes.
The design is similar to a "Kurt".
7th Jan 2020, 03:01 AM #6Most Valued Member
- 2,651
Is that a commercial or shop made one?
7th Jan 2020, 09:55 AM #7Golden Member
- Sep 2008
- 831
Hi Steve, I designed and built it to suit the machine, I now have to build another one for my Beaver Milling Machine. It will basically look the same with a few dimensions changed to suit with the same Electro pneumatic control as this one.
Lex.
7th Jan 2020, 10:48 AM #8Most Valued Member
- 2,651
Nice work Lex.
Would love to see some of the build when you do the next one.
Drawbar for the Hercus
By bwal74 in forum METALWORK PROJECTSReplies: 0Last Post: 26th Jan 2018, 09:59 AM -
Drawbar help.
By Jock67 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 6Last Post: 8th Aug 2016, 10:41 PM -
Drawbar Tool Removal
By oohsam in forum METALWORK GENERALReplies: 28Last Post: 28th Feb 2014, 05:59 PM -
Beefing up the drawbar - this OK?
By Wombat2 in forum TRAILERS & OTHER FABRICATED STUFFReplies: 4Last Post: 14th Sep 2012, 05:21 PM -
Combination drawbar tool
By Big Shed in forum METALWORK GENERALReplies: 3Last Post: 15th Nov 2009, 04:40 PM
