Results 16 to 23 of 23
Thread: More Christmas Goodies !
2nd Jan 2020, 10:37 AM #16Golden Member
- Cairns, Q
- 666
What Michael says - 18 DP, so not Drummond. If your Myford is pre-metric and has loose change gears they will be 20 DP. Might be interesting to check some of them to see how close they are to the theoretically correct diameter to produce exactly 20 DP.
Frank
3rd Jan 2020, 04:23 AM #17
I thought that I would post some pictures of the bits that had been in the citric acid bath.
First up the M&W callipers. I'm very happy with the way these came out ! They had two days, maybe 60 hours in a cold citric acid bath. I say cold because the workshop was only about 50F the whole time.
This 3 inch Bahco adjustable spanner cleaned up well too ! It was sized solid, so its been stripped and cleaned then lubricated. Just a pity about the pitting.
The scale came up quite well, its a good quality one as well. The callipers are a German brand, unfortunately the jaws have taken on some wear near the tips, but quite accurate between the body of the blades. The inside jaws don't seem to have had any use at all.
Last but not least is this item. Its been very well used. Non of the edges are sharp. All the teeth are worn as are the first 20 mm of the flutes. There are no visible markings on it to indicate what it is. Its 1/2" in diameter and 3" inches long. There is a hole in each end, but its not a centre as such since its flat bottomed.
Does anybody recognise this tool ?
Thanks Guys.Best Regards:
4th Jan 2020, 09:24 PM #18
Mystery Tool bit.
I'm surprised that no one has commented about this item.
Its been very well used. Non of the edges are sharp any more. All the teeth are worn as are the first 20 mm of the flutes. There are no visible markings on it to indicate what it is.
Its 1/2" in diameter and 3" inches long. There is a flat bottomed hole in each end.
5th Jan 2020, 02:20 AM #19
I've just discovered a bit more about this tool !
I decided to try and clean out the muck that was in the hole in the top and saw a hexagonal hole below. I couldn't figure out why there should be a hex hole there, so I stuffed an Allen key into it and discovered that there was a 10-24 UNC grub screw in there. I measured the threads on the grub screw, which was how I discovered that it was a 10-24 thread in the hole. It extends to about an inch deep.Best Regards:
5th Jan 2020, 09:08 AM #20
6th Jan 2020, 09:27 PM #21
Hi Ray,
Thanks for your post ! I think 1/2" diameter is probably a bit small for a blasting hole.
All the explosives that I've had my hands on have been sticks of gelignite about 1.5" inches in diameter and 8" inches long wrapped in waxed paper. You don't want to get the stuff on your skin either !
I'm guessing that the threaded hole is so that an extension rod can be screwed in to get extra length. I did wonder if it could be a counter bore of some kind.Best Regards:
7th Jan 2020, 12:15 AM #22Senior Member
- Perth, Western Australia
- 67
- 362
19th Jan 2020, 10:49 AM #23
More goodies !
By BaronJ in forum METALWORK GENERALReplies: 5Last Post: 23rd Aug 2019, 08:17 PM -
Scrap yard goodies !
By BaronJ in forum METALWORK GENERALReplies: 7Last Post: 6th Jul 2019, 09:36 PM -
Deckel FP1 plus other goodies for sale.
By KBs PensNmore in forum METALWORK - Machinery, Equipment, MARKETReplies: 4Last Post: 30th Apr 2018, 12:22 AM -
Wrecking Photocopies for Goodies
By Blu_Rock in forum METALWORK GENERALReplies: 13Last Post: 28th Apr 2014, 05:59 AM -
Got my first lathe and other goodies :d
By xXvapourXx in forum METALWORK GENERALReplies: 46Last Post: 20th Nov 2011, 11:41 PM
