Results 1 to 13 of 13
Thread: CQ 6230A dial
26th Dec 2019, 07:33 PM #1Novice
- Nov 2019
- NE Victoria
- 75
- 14
CQ 6230A dial
Hello Graham
I would like to find a more user friendly cross slide graduation dial, the dial that is on a CQ6230a is not a user friendly type.
Phil
26th Dec 2019, 08:27 PM #2
Hi Mechdraw,
Most of us don't have a CQ 6230A lathe so it would help just a little a bit if you can describe the features or lack of, for this dial and why the cross feed dial is not user friendly.
What about the cross feed dial causes problems for you?
Unfortunately lathe dials are not like car acessories and you can't just buy an upgraded part as the maker, if still in business is making lathes several generations in advance of what you own now.
Honestly, folks are pressed even rounding up a manual for the these lathes. If any thing is to be done I suspect you may have to make something yourself.
You might be lucky and encounter a member here who has made a new dial and is able to offer advice.
26th Dec 2019, 08:51 PM #3Novice
- Nov 2019
- NE Victoria
- 75
- 14
CQ 6230A dial
Hello Graham,
Thank you for the reply.
The CQ6230a cross slide dial is in graduations of .04mm, secondary graduation, the main graduations, "0" to "1" works out to 0.80mm???
When you have been used to dials in .001" or .02/.01 most of your working life .04 is strange to say the least.
By making a larger diametre dial should allow more graduations, am I right in assuming this?
I hope there are others with a similar issue and together we can work it out.
Phil
27th Dec 2019, 12:14 PM #4
Hi Phil,
Being the Xmas season I assume many of the folk who could answer your question are away from their keyboards.
Those who might be best able to answer your inquiry could be away for a while yet.
Unfortunately for you, that leaves just me and I don't know all that much.
I run a later series lathe - the Metalmaster 12 x 36 about 2007 vintage. My cross slide MM increments (100 of them) are .02 each which I think, makes my cross slide screw pitched at 2mm. There are imperial increments but I do not use them so they shall be left off a new dial if one is ever made.
I too would like to make a new dial,but just with mm increments but make it from aluminium which would be better to machine and scribe as a well as offer the better corrosion protection. I can recall having difficulty with reading the first Hercus lathe dials I used at school as a teacher. The readings where illegible.
While we are waiting for someone who has done it, here is a link to Tubal Cain/Mr Pete 222 and what he has to say on the matter.
https://www.youtube.com/watch?v=NF55...ature=youtu.be
and
Some discussion from our own blokes in 2017
https://metalworkforums.com/f65/t200...s-metric-lathe
27th Dec 2019, 12:46 PM #5Novice
- Nov 2019
- NE Victoria
- 75
- 14
CQ 6230A dial
Thanks Graham
A very informative reply.
Phil
27th Dec 2019, 02:23 PM #6Philomath in training
- 6,541
G'day Phil
I think it is too much Christmas lunch as I'm a bit slow here but this is a dial I made up for my lathe many years back. Later models came fitted with this dial but mine did not, so I made one up.
The process is easy - just make up the new dial and using a dividing head, scribe the required divisions on it. (Note the bit of flat in the scribing jig - there are 3 of them and they act as stops to limit the length of the scribed lines). To try and get the numbers straight I also made up a jig to help stamp them on.
I guess the key thing is the leadscrew pitch. As long as you chose your divisions so they divide neatly there should be no problems. In the example above, the carriage travels 1" for a complete turn, so the divisions were 5 thou multiples to get nice (readable) spacing.
27th Dec 2019, 03:45 PM #7Senior Member
- Feb 2009
- jilliby nsw
- 111
Nice work there MichaelG, very impressive
27th Dec 2019, 06:26 PM #8Senior Member
- Jul 2007
- 332
Phil,
I suspect what you have is an Imperial lead screw and a Metric dial which leaves an odd number at the end of a rotation. A lot of Asian sourced lathes years ago were made for the American market, hence Imperial measurement. As already mentioned making a new dial would be 1 option or possibly a digital readout. Good luck with it. Alan.
27th Dec 2019, 07:43 PM #9Novice
- Nov 2019
- NE Victoria
- 75
- 14
CQ 6230A dial
Thanks Alan,
I think You're right it does finish with an odd number at the end. I will look at a new dial first.
Phil
29th Dec 2019, 02:51 PM #10Senior Member
- Dec 2010
- Syd
- 492
For better utility and speed, I'd shove a DRO on it, way, way, before mucking around with dials. Under $500 should get you there.
29th Dec 2019, 03:46 PM #11Novice
- Nov 2019
- NE Victoria
- 75
- 14
29th Dec 2019, 09:05 PM #12
Hi Phil, Guys,
It won't be the first time that I've used a cheap electronic calliper as a poor mans DRO !Best Regards:
31st Dec 2019, 09:19 AM #13Senior Member
- Dec 2010
- Syd
- 492
Chinese lathes? specifically the CQ-6230A
By mattybgt in forum METALWORK GENERALReplies: 27Last Post: 10th Dec 2016, 11:32 AM -
dial indicator
By fittermachinist in forum METALWORK GENERALReplies: 30Last Post: 12th Aug 2012, 12:20 AM -
dial fault
By nadroj in forum THE HERCUS AREAReplies: 12Last Post: 27th Jun 2011, 12:00 PM -
A new 6230A and a question
By Roulston in forum METALWORK GENERALReplies: 11Last Post: 3rd Dec 2010, 06:40 AM -
Big dial, little dial?
By neksmerj in forum THE HERCUS AREAReplies: 2Last Post: 30th Jan 2009, 11:32 PM
