Results 1 to 15 of 28
Thread: Bench grinder vibration
18th Dec 2019, 12:49 PM #1
My bench grinder has a very annoying vibration, not severe, just enough to make it unpleasant to use.
Interestingly, the vibration stops as soon as the power is cut, and coasts to a perfectly smooth stop.
Bearings are not worn, and wheels are secure.
Any suggestions greatly appreciated.
18th Dec 2019, 01:05 PM #2Senior Member
- Aug 2012
- Greenmount, W.A.
- 70
- 275
Have you tried taking one wheel off at a time?
18th Dec 2019, 01:16 PM #3Novice
- Jul 2019
- Texas
- 15
Mine had the same problem. You can try buying a new grinding wheel, or I built a belt sander attachment for mine. I made a video describing exactly your problem and my solution.
https://youtu.be/-Bp_TB87PxY
Sent from my SM-G950U using Tapatalk
18th Dec 2019, 01:19 PM #4
18th Dec 2019, 01:35 PM #5
Funny you should post that, as I recently joined a facebook page dedicated to home build belt grinders, but they seem to require a fair bit of shed realestate which put me off.
This on the other hand only requires a bit of height, which I have plenty of
Thanks for that, it is certainly an option.
18th Dec 2019, 03:25 PM #6China
- Dec 2005
- South Australia
- 1,658
Take both wheel off run machine, if it vibrates then it is the machine, bent shaft warn bearing ( crap brand ) check wheel(s) are not cracked, balance wheels and reassemble should be fine
18th Dec 2019, 03:37 PM #7Most Valued Member
- 4,890
Did dressing the wheels have any effect?
18th Dec 2019, 03:53 PM #8Golden Member
- Dec 2011
- 505
Could it be that with two wheels on you have just the right mass for the inherent vibration in the motor when powered (I presume a single phase motor) to trigger the resonant frequency of the system (= grinder + bench or stand)? If so maybe adding mass (eg. heavy plate under the grinder) or some damping to the system would help.
My little Bergin bench grinder came with soft 'grommet' style rubber feet that even after 4+ decades seem very effective as dampers, both when free standing or screwed to the bench.
This type of problem also seems to happen with grinders mounted on floor stands made of thin sheet steel.
Bill
18th Dec 2019, 04:21 PM #9Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Bench grinder
Hello from BC.
If you have toolroom wheels with a srtipe going from centre to rim the wheels should be mounted with the stripe upwards. This is the heavy side and the slack at the hub helps to balance the system. If they are GP wheels loosen 1 at a time and turn 1/4 turn and retighten. You will find the sweet spot for each wheel like this but complete one wheel at a time. A lot of the problem is caused when the rotor is stick welded to the shaft. Usually both on the same side. Also don't dress the side of the wheels as these can be vapour blasted to balance the wheel. Good quality wheels make a difference but to find them?
19th Dec 2019, 12:03 AM #10
Both wheels have been replaced at different times with supposedly good quality ones, and it did improve the issue, but didn't cure it.
It is mounted on a stand made of very thick walled square tube as the vertical, with a steel wheel rim as the base.
The harmonic vibtation suggestion seems to fit, because as soon as the rpms drop a fraction after powering off, it is as smooth as silk. I recon if I could run it at 50rpm less it wouldn't do it at all.
I'll try some of the suggested remedies over the next couple of days, might get lucky.
Cheers.
19th Dec 2019, 12:13 AM #11Novice
- Jul 2019
- Texas
- 15
I'm most likely going to upgrade it to accept a 4" belt, which are easier to find in a variety of grits. This project is a very easy welding project and it is 1000 times more convenient than the old grinding wheel. If you do decide to make it, please comment on the video any suggestions for improvement. Thanks!!
19th Dec 2019, 03:02 AM #12
19th Dec 2019, 03:27 AM #13Novice
- Jul 2019
- Texas
- 15
I never thought about the motor. That is a good point. Mostly I was thinking that I dont have problems now, and that the 4" belts are easier to find at my local supply store here in Texas.
If I have to upgrade the motor, then I would have to have an altogether much larger machine, which wouldnt fit on my small workbench. I also dont gave a lot of room in my suburban garage for a big grinder.
19th Dec 2019, 06:48 AM #14
Hi Weekend.Warrior,
Most small 500-750 Watt bench grinders will happily run a 100 mm abrasive belt. Problems arise when you want to do more than the motor is capable of. I have a commercial 100 mm belt grinder and it only has a 350 watt motor, as long as you don't put too much pressure on the belt, it does fine.
I also have a home brew finger sander that uses a 13 mm wide belt that I built using a 100 watt 3000 rpm pump motor. Now that one just rips metal off if you press too hard.
The bottom line is how much metal do you want to remove and how fast !Best Regards:
19th Dec 2019, 08:28 AM #15Member: Blue and white apron brigade
[QUOTE=ptrott;1960465]Both wheels have been replaced at different times with supposedly good quality ones, and it did improve the issue, but didn't cure it.
It is mounted on a stand made of very thick walled square tube as the vertical, with a steel wheel rim as the base.[QUOTE]
How does it run if you take it off the base? Just on a bench.
The harmonic vibration suggestion seems to fit, because as soon as the rpms drop a fraction after powering off, it is as smooth as silk. I recon if I could run it at 50rpm less it wouldn't do it at all.
Bench grinder advice
By brendanh in forum METALWORK GENERALReplies: 23Last Post: 20th May 2015, 11:46 PM -
Bench Grinder Upgrade
By Jim Ferrous in forum METALWORK GENERALReplies: 12Last Post: 22nd Oct 2013, 01:30 AM -
bench top for a bench grinder
By wodstok in forum METALWORK GENERALReplies: 1Last Post: 24th Jan 2011, 03:04 PM -
Bench grinder problems
By new_guy90 in forum METALWORK GENERALReplies: 5Last Post: 7th Feb 2009, 02:45 PM -
Which 200 mm bench grinder should I buy ?
By Retromilling in forum METALWORK GENERALReplies: 15Last Post: 16th Oct 2008, 11:31 AM
