Results 1 to 8 of 8
17th Dec 2019, 06:23 PM #1New Member
- Nov 2019
- 5
Waldown 8sn series III spindle with JT6 taper
Hi,
I bought an old Waldown pedestal drill press 8SN Series III for restoration and put it in my workshop later.....
This is my very first drill press.
Few weeks ago, I pulled out a Jacobs #34 keyed chuck and
I see a damaged thin brass sleeve inside taper hole....I have no idea...
But now......I think that JT6 taper on spindle has been shaved off a bit on lathe and
added a thin brass sleeve on it to hold the chuck together.......is that right?
I wanted to add a new keyless chuck .......but first, what should I do? where can I get a new sleeve?
or look for another spindle?
- John
17th Dec 2019, 09:38 PM #2
Hi John,
Welcome to the forum
I've seen that trick done, using brass or copper shim to fix a damaged spindle taper. Very often the damage is just scoring and can be cleaned up with fine emery cloth. The drill chuck should push almost all the way on the taper. Screw the jaws fully back inside the body and using a block of hardwood between the chuck nose and the table press the chuck onto the taper. It should fit firmly in place without any shims.
If it is loose at this point then you will need to replace the shim and go through the fitting operation again. The chuck should run true without any wobble. A wobble could indicate that the spindle might be bent.
As far as a new chuck is concerned, there are at least two different tapers in common use, JT and BT ones. They are not interchangeable.Best Regards:
17th Dec 2019, 11:24 PM #3Most Valued Member
- 5,945
Hi John welcome to a TOP FORUM, any chance of a pic of your spindle please?
Your chuck should go back on without the extra shimming, that's why they are tapered. About the only thing that would prevent it seating, is if the taper itself is worn, or that it's too long for the chuck.
18th Dec 2019, 06:51 AM #4Philomath in training
- 6,542
This table of Jacobs tapers is from littlemachineshop.com (just because it was the first to come up with on google)
Taper Large End Small End Length Taper/
FootTaper/
InchAngle From Center #0 0.2500 0.2284 0.44 .5915 .0493 1.4117 #1 0.3840 0.3334 0.66 .9251 .0771 2.2074 #2 0.5590 0.4876 0.88 .9786 .0816 2.3350 #2 Short 0.5488 0.4876 0.75 .9786 .0816 2.3350 #3 0.8110 0.7461 1.22 .6390 .0532 1.5251 #4 1.1240 1.0372 1.66 .6289 .0524 1.5009 #5 1.4130 1.3161 1.88 .6201 .0517 1.4801 #6 0.6760 0.6241 1.00 .6229 .0519 1.4868 #33 0.6240 0.5605 1.00 .7619 .0635 1.8184 As you can see, a JT6 and a JT33 are very close. I'm wondering whether the shim is there because the taper on the chuck is not the same as the taper on the spindle...
Just a thought, as that shim should not be needed.
18th Dec 2019, 07:31 PM #5Most Valued Member
- Charlestown NSW
- 1,669
A lot of chucks (good ones at least) have the taper size etched onto the body of the chuck somewhere. Usually near where the capacity is etched.
19th Dec 2019, 08:44 PM #6New Member
- Nov 2019
- 5
Thank you very much for replies
I cannot find taper size marker on old #34 British-made Jacobs chuck.....without shim, it will drop like a stone......I can feel it very loosely......like a mil gap.
I'll ask my brother to borrow a digital vernier caliper measurement from his work......to find out what size...... maybe reduce to JT33 at the machine shop and get a new 1-13mm keyless chuck with JT33....I don't know....I'll just wait for measurements.
Some pics of my spindle...............
IMG_4336.jpgIMG_4337.jpgIMG_4338.jpgIMG_4339.jpgIMG_4340.jpgIMG_4341.jpgIMG_4342.jpgIMG_4345.jpg
I'll look for another spindle with Morse taper.......it's nice to have that......
Thanks again
- John
19th Dec 2019, 10:25 PM #7Most Valued Member
- 5,945
Thanks for the pics John, unfortunately that doesn't really help us determine the cause, as everything looks Mickey Mouse.
Would it be possible to get pics of the inside taper of your chuck and any markings, please?
Someone may recognise it or the problem.
It could also be possible that you have a DIN238 series chuck? Or that you have the 33 chuck with a 6 arbor?
https://uk.roehm.biz/fileadmin/produ.../DC0000321.PDF
20th Dec 2019, 10:22 PM #8
The number 34 Jacobs chuck was made with several sizes of arbour sockets. There should be a number after the 34 - xx that tells you what taper it is.Best Regards:
Spindle taper I.D. ?
By morrisman in forum METALWORK GENERALReplies: 3Last Post: 18th Mar 2018, 04:19 PM -
Cat 30 taper spindle
By Mike4 in forum METALWORK GENERALReplies: 4Last Post: 16th Oct 2015, 11:07 AM -
Waldown 8" Series II Grinder tart up x 2
By Piers037 in forum METALWORK GENERALReplies: 23Last Post: 27th Feb 2013, 09:33 AM -
Spindle taper size
By TomW in forum THE HERCUS AREAReplies: 5Last Post: 24th May 2012, 05:02 PM -
Waldown Type 8SN Series III Rebuild
By RayG in forum METALWORK GENERALReplies: 95Last Post: 25th Jan 2012, 05:45 PM
