Results 1 to 6 of 6
Thread: shrinking disc
13th Dec 2019, 12:30 PM #1
shrinking disc
A tool panelbeaters use, a disc mounted on a angle grinder. Would it be possible to make a disc out of stainless, rather than buying one ? They are not cheap to buy . The friction heats up the area to be shrunk , usually a spray of water is used .
13th Dec 2019, 05:12 PM #2Most Valued Member
- 2,651
I can't see why not.
They are ~1.6mm stainless according to this:
https://www.autobodytoolmart.com/shr...s-p-15602.aspx
13th Dec 2019, 05:31 PM #3Most Valued Member
- 2,651
The commercial ones look like they are pressed out of sheet, but I reckon it would be hard to get that outer flange formed nicely and keep the face flat fabricating one yourself. I don't think the thickness is critical, more that they form them out of 1.6mm for manufacturing reasons.
I think it might be easier to turn one up out of plate. Probably 6 or 8mm would be thick enough to get a similar radius on the edge as what the commercial ones have, recess the center for the flange nut and just leave the rest original thickness.
14th Dec 2019, 02:37 PM #4
Does this help?
Pauls splitscreen van project: How to make a metal shrinking disc
14th Dec 2019, 09:18 PM #5
Shudder ! No guard He's lucky he still has fingers.
14th Dec 2019, 11:50 PM #6
Common sense should have told him that the 4" grinder was too small for the disc.
The other way would have been to extend the A/G handle.
Common sense is not always common.
Disc Sander RPM
By Dusty Wheels in forum METALWORK GENERALReplies: 10Last Post: 1st Aug 2019, 04:40 AM -
Disc sander build
By Pete O in forum METALWORK PROJECTSReplies: 10Last Post: 11th Jan 2019, 03:31 PM -
witch cutting disc do you use?
By wodstok in forum WELDINGReplies: 12Last Post: 10th Feb 2011, 08:39 AM
