Results 1 to 15 of 199
Thread: Punch 12mm hole in 8-10mm steel
13th Dec 2019, 05:21 AM #1Most Valued Member
- Aug 2009
- Sydney, NSW, Australia
- 1,836
Hi guys is it possible to make a home made 12mm punch to make 32x 12mm holes in 8-10mm steel?
I absolutely dont want to be drilling that many holes its a boring job
Looking to use the punch in my 20t hydraulic press
13th Dec 2019, 06:31 AM #2
Just hire/borrow a mag drill and buy a 12mm rotabroach. Wont take very long to drill that many holes. Less time than it will take to make a punch and die.
13th Dec 2019, 07:00 AM #3
Hi Gazza,
I fear Its going to take a bit more than 20 tons to knock 12 mm diameter hole in 10 mm steel.Best Regards:
13th Dec 2019, 07:14 AM #4Philomath in training
- 6,540
An hour, maybe 2 if you are really slow
Depends on complexity but based on making up some simple dies for people, probably 20+ hours. That does not include waiting time for heat treating the punch and die, order and delivery of tool steel. It also assumes you have a cylindrical grinder to get final dimensions on the punch and something that can do the work of a jig grinder to finish the die.
13th Dec 2019, 09:18 AM #5Most Valued Member
- 4,887
No.
13th Dec 2019, 09:29 AM #6
Hi gazza
I would say no.
Assuming your press has that capacity. Here's a yank link to check it. https://www.americanmachinetools.com...punch_hole.htm
I would ask is the press manual or an air over hydraulic ,ie non manual.It s manual its going to be a slow exercise indeed. Some 32 holes is not a lot but the amount of manual pumping and then the die stripping is not going to be a quick process either.
As one who has punched thousands of holes in 20mm flatbar, I can tell you that the punching machine required to do so is an extremely heavy and rigid unit.
You need a well made heavy duty die box to locate and retain the female die.The female die opening must be 10% larger in diameter than the male die diameter.
This female die must be made to allow for expansion of the pressed slug of metal removed.The metal slug compresses and expands as it is pushed through the female die opening. Female dies are tapered from entry side to exit side to avoid jamming which in turn may result in die breakage.
The male punch needs a positive way of locating it centrally and rigidly with absolutely no possibility of any movement. The lateral movement in many utility hydraulic presses would not likely maintain the precision straight up and down movement demanded on each cycle stroke.
As for the male and female dies themselves the manufacture should be left to someone well experienced in the process. Die making is really the province of a tool maker as they are trained to do it.To tackle them yourself could well result in a messy removal from the gene pool if something goes wrong. A guess here but a commercially made one might see you well over $100 .
For the amount of effort going into such a project for the result hardly seems seems to warrant it.
All in all, I believe you are better served by marking out the holes and getting a local engineering works to punch the holes for you or go the mag drill route.
13th Dec 2019, 11:01 AM #7Most Valued Member
- Sep 2010
- Lebrina
- 1,910
I'd give the same answer that everyone has given, possible, yes, practical, no. If the components are something that can be taken to a drill press, then 32 holes is not a big job at all and even if you have to do them with an electric drill, provided the drill can be slowed sufficiently, (under 1000RPM and ideally 750RPM) and a pilot drill used, (3mm or so), then 32 holes will be done fairly painlessly. A cutting compound while not essential will ease the process.
I wouldn't contemplate borrowing/hiring a mag drill for a mere 32 holes @12mm. For the cost of hire you could buy a low end electric drill if you didn't already have one.
Work on the KISS principle for this one.
13th Dec 2019, 02:24 PM #8Gear expert in training
- 34
- 1,075
13th Dec 2019, 02:24 PM #9China
- Dec 2005
- South Australia
- 1,656
I use a 20 ton press to cut discs from 1mm 2mm silver sheet, I can assure you a 20 ton press will not do it
13th Dec 2019, 02:31 PM #10Gear expert in training
- 34
- 1,075
Just out of curiosity, I checked a few punch tonnage calculators online and they're all saying about 15 tons to punch those holes in mild steel. That's 15 US tons, so about 13.6 metric tons.
13th Dec 2019, 08:48 PM #11Most Valued Member
- Aug 2009
- 1,836
Thanks guys i just really dislike drilling steel and 32 holes will take forever, i can come down to 6/7mm material if need be
Im making steel L brackets to support my boat trailer bunks at the base on the cross members i need to use 16 brackets and they U bolt on so i need 32 holes in 12mm
I thought the punch would be easy to machine on the lathe seems i am way off
I appreciate the advice give
13th Dec 2019, 09:13 PM #12
If drilling 32 odd holes is a chore, then it would seem that you drills may be blunt or sharpened wrong.
It should be a doddle, not like you are drilling 32 mm holes...
JoeCheers, Joe
13th Dec 2019, 09:45 PM #13Most Valued Member
- 5,942
Gazza, do you have a drill press?? If not are you able to get one, even a benchtop will do, if you can't get one, do you know someone who has one that you could go around too and use?
Having a drill press would be one of the first things anyone contemplating metal work should have, along with some decent quality drills.
When you say 12mm holes is that to take 12mm bolts or 10mm bolts?
13th Dec 2019, 09:50 PM #14Diamond Member
- Aug 2006
- 1,105
I wouldn't bother about making a punch and die when you can buy them cheaply enough.
https://www.ebay.com.au/itm/CH-60-31-Ton-Hydraulic-Punch-Dies-Die-Sets-CUTS-COPPER-STEEL-ALLY/332245247671?hash=item4d5b5c26b7:m:mxDaLpK-N8bfEm3VvZ-tvHQ&frcectupt=true
You can also buy cheap hydraulic punches.
https://www.ebay.com.au/itm/CH-70-Hy...oAAOSwZKFc7x69
I'd probably just drill them though as the others have suggested. I would use a drill press for accuracy.
13th Dec 2019, 10:58 PM #15China
- Dec 2005
- South Australia
- 1,656
Interesting elan I am tempted to buy a punch just to try it out
Lever action hole punch information
By KBs PensNmore in forum METALWORK GENERALReplies: 14Last Post: 28th Sep 2018, 09:21 PM -
Resharpening rotary hole punch
By neksmerj in forum METALWORK GENERALReplies: 0Last Post: 9th Jun 2015, 07:01 PM -
Drilling 30mm hole through 10mm plate
By Stephen H in forum METALWORK GENERALReplies: 57Last Post: 29th Mar 2014, 12:39 PM -
whats a good welder? welding 10mm / 12mm steel mig gas or gasless wood fire heater
By makitaLXT in forum WELDINGReplies: 3Last Post: 30th Jun 2013, 10:58 AM -
How to bend 10mm or 12mm steel tube
By jabell in forum TRAILERS & OTHER FABRICATED STUFFReplies: 8Last Post: 2nd Nov 2012, 04:35 PM
