Results 1 to 11 of 11
    May 2009
    Sydney
    75
    Default Way oil available to pick up - northern Sydney
    I just took delivery of 20L of Tacway 68 way oil (Tacway 68 & 220 - Gulf Western Oil - Gulf Western Oil). 20L of it will go bad before I use it all, so if anyone wants some send me a note and if you bring a container you can have some for what I paid ($6 / litre).
    I'm near Wahroongah.
    Phil.
    Dec 2011
    Rosebery/Eastlakes
    115
    Hi Phil,
    How much are you wanting to get rid of?
    Sent from my SM-N960F using Tapatalk
    Mar 2008
    nowra
    1,598
    Hi mate I would be interested in a couple of liters.
    Andre
    May 2009
    Sydney
    75
    Quote Originally Posted by Flo View Post
    Not trying to get rid of any specific amount. Just offering to fellow garage metal chip makers. I hate buying it at $20/litre from EBay profiteers. 5L will last me years.
    Phil
    May 2009
    Sydney
    75
    Quote Originally Posted by welder View Post
    Hi - just send me a PM and I'll give you a number to SMS me on for details. Bring a container and we'll pour you some.
    Ditto for anyone else, just PM me.
    Phil
    Dec 2011
    Rosebery/Eastlakes
    115
    Hi Phil,
    I'd be happy to take 5 litres.. I'll PM you later..
    Adam
    Edit: quantity..
    May 2009
    Sydney
    75
    Just to be clear this is for machine ways. If anyone is looking for a good buy for headstock / gearbox oil, Bunnings (eck!) sells Valvoline ISO 68 for $32 for 5L, ($79 for 20L in some stores): https://www.bunnings.com.au/valvolin...il-5l_p0066175
    If you have lathe with an open screwcutting gearbox like my AL-960B you go through a lot of gearbox oil...
    Phil.
    Dec 2011
    Rosebery/Eastlakes
    115
    Thanks for the clarification Phil!
    Flo
    Dec 2013
    56
    1,418
    Quote Originally Posted by SP_Flip View Post
    Phil.
    My lathe goes through no oil, sounds like the tiawonese lathes are oil hungry.
    Using Tapatalk
    6,481
    My Myford drinks the stuff ! There is a permanent puddle under the headstock.
    May 2009
    Sydney
    75
    Per my post it's an *open* Norton gearbox. Nothing to do with being Taiwanese. The screwcutting gearbox is open at the bottom: each day you squirt some oil into a pad at the top and it drips through some strategically positioned holes onto the gears and bushings and the excess drops into the chip tray. This is the traditional design of gearbox. At least it has a good design for the reservoir: in classic lathes (eg the South Bend 9" that's the template for so many small lathes) you squirt the oil up from underneath. You just don't clean the chip tray with compressed air or you blow all the chips up there.
    The 960B is excellent. I'd rate it the best value medium workshop lathe in Aus right now. You can buy it for the same in $Au as the Americans pay in US$ for the same machine with the same features, and the quality is first rate. The design is dated, but the manufacturing equipment must be right up to date as fit, finish and (most importantly) accuracy are excellent. Even the 3 jaw is repeatable to about 0.05mm / 0.002" or so.
  1. Ad wanting weldor northern NSW
    By WelderMick in forum WELDING
    Last Post: 26th Feb 2017, 05:09 PM
  2. Anyone able to pick up a benchtop surface grinder in/near Liverpool, Sydney
    By KBs PensNmore in forum GENERAL DISCUSSION / OFF TOPIC
    Last Post: 8th May 2016, 03:57 PM
  3. Anyone able to pick up a surface grinder in/near Liverpool, Sydney
    Last Post: 3rd May 2016, 11:27 PM
  4. Grays Auction pick-up Sydney
    By Theberylbloke in forum METALWORK GENERAL
    Last Post: 8th Mar 2016, 08:04 AM
  5. Replies: 5
    Last Post: 6th Feb 2016, 10:10 PM
