Results 1 to 11 of 11
    Nov 2008
    North Brisbane. Qld. Australia
    70
    1,511
    Default Ratchet and Pawl source
    Anyone know of a source for small ratchets and pawls? Need something with an OD of around 50mm, 36 teeth, 12mm bore and 10 to 12mm width. Can't find anything close to this. Will consider other sizes and tooth count.
    Nev.
    May 2011
    Murray Bridge S Aust.
    5,945
    Have a look at boat winches, whether they have enough teeth I don't know. If we had an idea as to what you're trying to make, other ideas may come to light. I have several gears here that would do, and the pawl could be a bit of flat bar welded to some rod, with a spring to hold it in place, is that the type of thing you're wanting?
    Gears out of a car gearbox with bushes to reduce the bore to 12mm is another choice. As I said earlier, if we know what you're trying to achieve, it could be a better mousetrap?
    Nov 2008
    70
    1,511
    Might be a good idea, might not. Going to convert the bench drill to a single lever. Just seems like raising the lever to what is a convenient position to start drilling, rather than the choice of three handles that never seem to be in just the right position would be better.
    Nev.
    6,444
    Hi Nev,
    My "FOBCO" drill press uses a single sliding bar handle with a lock screw so that you can set it to any length you want. The only problem that I have with that is if I'm tapping a hole and unscrewing the tap, sometimes you have to play "dodge the handle" or it can smack you in the face.
    May 2011
    5,945
    I adjust the table to get the handles right.
    Sep 2007
    Wentworth Falls NSW 2782
    77
    134
    Have you considered using a modified socket ratchet?
    Findlay
    May 2011
    5,945
    If that's what you're planning to do, have you thought about your quill, as will require some sort of resistance, otherwise it'll just flick back up again.
    Nov 2017
    Geelong, Australia
    57
    2,651
    Quote Originally Posted by MacPuddock View Post
    Findlay
    Along a similar line, perhaps either a ratchet spanner or a roller clutch. Roller clutch would give infinite positions rather than being limited by the tooth count on a ratchet.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,542
    A ratchet is an easy thing to make up on a mill with a dividing head. I guess you could even produce a ratchet with a file if you needed one. Similarly, a pawl is just a length of material that gravity or a spring holds against the ratchet.
    Mind you, 36 teeth on a 50mm OD is a pretty fine tooth spacing. The step is just under 0.4mm, the run to the next step is only 4.3mm. I'd suggest a sprag bearing except they can not reverse.
    Can you do something like a knurled collar with a clamp on handle so you can adjust the position easily?
    One thing that most people forget (and I do myself on a regular basis) is that the 3 spoke handle on something like a Waldown drill press is adjustable for position. If you undo the big Bakelite nut, it will slide off and can be moved around. The spline on there is a 10 tooth one, so the spoke handle can be moved around in 36 degree increments. That, combined with lifting the table, seems to get around any isses I have.
    Charlestown NSW
    65
    1,669
    Another method that hasn't been mentioned is system used on Bridgeport mills (and clones).
    Only one arm and the centre boss slides along the pinion shaft with a detent to hold it in place. Flange on shaft behind the boss with a number of holes drilled in the face. The boss has a pin in the back that mates with the holes in the flange. You pull the handle and boss out till the pin is clear, rotate to the desired position , then push back in until the pin engages. Works well.
    peter
    Nov 2008
    70
    1,511
    Thanks for the extra ideas everyone.
    Nev.
  1. Douglas shaper ratchet
    By Ueee in forum METALWORK GENERAL
    Last Post: 19th Sep 2013, 12:23 PM
  2. Gedore 80mm Ratchet Ring Spanner
    By Pat in forum METALWORK GENERAL
    Last Post: 1st Nov 2012, 10:47 PM
  3. Shaper table feed ratchet
    Last Post: 7th Jun 2012, 02:27 AM
  4. VICTORIA Powerbuilt Sockets, Ratchet, Breaker bar, 3/4"
    By TermiMonster in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 6th May 2012, 09:14 PM
