Page 3 of 6 FirstFirst 123456 LastLast
Results 31 to 45 of 83
  1. #31
    Jul 2016
    35
    1,522
    There is no way you will get that welded and re machined for $65. Also my experiences with welding annoy castings has been unpleasant to say the least.
  2. #32
    Nov 2012
    Mid North Coast NSW
    423
    OK next problem.
    I tried removing the facing cutter that's in it.
    It seems to be stuck pretty hard. Isn't it just a matter of loosening the drawbar nut and giving it a whack with a hammer ?
    That didn't work. The guy that sold it to me said he only used it for one task which was milling a face on something so this cutter prob hasn't been removed for years.
    I don't know what the drawbar should look like but it's only threaded rod in there now.
  3. #33
    Dec 2013
    56
    1,418
    Looks like a round column mill drill, so it will be either MT3 or R8, if so you need to give it one good hit with the quill locked and I'd use a piece of aluminum between
    to save the threads on the draw bar.
    As you said it's probably stuck over the years.
    Using Tapatalk
  4. #34
    Jul 2016
    35
    1,522
    If it's stuck it's because its a Morse taper. You are probably going to need a significant shock to get it out.
  5. #35
    Jul 2016
    35
    1,522
    I would probably take the drawbar all the way out, then make a close fitting drift and wail on that. The drawbar is probably bending and dissipating all the energy from your hammer blow.
  6. #36
    Dec 2013
    56
    1,418
    Default Chuck has a ring
    Using Tapatalk
  7. #37
    Nov 2012
    Mid North Coast NSW
    423
    Quote Originally Posted by caskwarrior View Post
    Yes it is Morse 3
  8. #38
    Dec 2013
    56
    1,418
    This is my old crane I built
    Home made jib crane for the shop
    Using Tapatalk
  9. #39
    Dec 2013
    56
    1,418
    I also made boxes for the rotary table, chucks and faceplates. Everything has lifting points so easy accessed by the crane hook.
    Using Tapatalk
  10. #40
    Nov 2012
    Mid North Coast NSW
    423
    Had to duck into town.
    When I came back I used a bigger hammer and out it popped.
    Another thing I found...The motor was mounted around 20mm too low so the belt wasn't lined up very good. I don't know why the guy left it like it.
    So I lifted it up to where it should be. While fiddling with that is when I discovered the broken pulley. So part of that was of course the belt adjustment.
    I reckon it will take me 20 mins every time I want to change speeds on this thing. It's a pain in the royal butt.
  11. #41
    Dec 2013
    56
    1,418
    I have a vfd for my mill and motors to fit when I get around to it.
    I just stay around the 4 speeds that doesn't need belt swapping.
    Using Tapatalk
  12. #42
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    Quote Originally Posted by phaser View Post
    Any ideas for repair or where to get one ? ... maybe if I can find someone locally to build up the aluminium and I can machine it back to normal. Maybe that can't be done if it's magnesium ?
    Attachment 383611
    Unlikely to be magnesium - would be too expensive. For that one I would machine off the top flange (leaving a round spigot, machine up a disc from Al with a hole to fit the spigot and then weld it in place. Reprofile to suit.
  13. #43
    May 2011
    Murray Bridge S Aust.
    5,959
    Any chance of a pic of your motor adjustment please. It may be possible to fit one of several items to make speed changing quicker.
    If the motor is mounted on a hinge type arrangement, a push type toggle lever could be fitted. If it's mounted on twin sliding bars, some sort of cam arrangement might be suitable.
  14. #44
    6,473
    Hi phaser,
    Hi Phaser,
    Yes ! I have the same stand, from memory its 32" inches tall, but I'll measure mine and check later. I have mine sat on a piece of rubber conveyor belting. Otherwise it rocks slightly. Mine was supposed to have a lock in the door handle but it doesn't and there is no provision for one.
    Yes I can confirm the height as 32" inches for the cabinet plus 1" deep for the catch tray and another 5.5" inches to the mill table surface. so 37.5" in total.
  15. #45
    Nov 2012
    Mid North Coast NSW
    423
    Yep, here it is.
    I was thinking of a couple of ideas myself, that I could do to it once I get it cleaned up and mounted on the stand. A couple of the free items it came with are lots of thick dirt and a kilo of sharp swarf.
    It will need a big clean and lube. X and Y are hard to move and winding the head is near impossible. Once I get the machine freed up I'll seriously consider mounting some sort of motor drive for the head, just need to find a cheap DC motor with a worm drive larger than a windscreen wiper.
  1. Ring roller
    By KBs PensNmore in forum WANTED TO BUY
    Last Post: 21st Jun 2018, 12:23 AM
  2. Another ring roller
    Last Post: 15th Apr 2017, 01:12 PM
  3. H&F Ring Roller
    By Dingo Dog in forum METALWORK GENERAL
    Last Post: 13th Apr 2017, 09:26 PM
  4. O-Ring Supplier
    By Normanj in forum METALWORK GENERAL
    Last Post: 30th Nov 2010, 09:36 AM
  5. Ring making
    By Eindringling in forum METALWORK GENERAL
    Last Post: 6th May 2007, 03:03 AM
