Results 1 to 10 of 10
    Aug 2011
    4,779
    Default Bijur one shot metering proportioners
    Hi all,
    For some time I have been looking at replacing the one shot metering valves on my mill. I have ultrasonically cleaned them to an inch of their life but I suspect they need replacing. A single pull on the lube pump seems to take 1/2 a day for the oil to ooze out of these No.3 oilers, perhaps a bit quicker with ISO15 hydraulic oil but still, It seems a bit slow.
    So far I can only find two places that stock them for a reasonable price; Arc Euro Trade and also an eBay store in the US. The US ebay site has them for US $5.00 for two which is about as cheap as you can get them but by the time you ship them here, the price goes up. Is there anywhere in Aus that sell these or similar items?
    6,443
    Dec 2013
    56
    1,416
    AliExpress mate, they have both types of oil systems SLR and PDI, you can buy a whole system for under $80 with all lube points tubing etc.
    Also all fittings are available separately so cheap
    Using Tapatalk
    Dec 2013
    56
    1,416
    Here is a screenshot of one seller
    Using Tapatalk
    Aug 2011
    4,779
    Thanks Baron, thanks Dave.
    I'm glad I asked!
    Baron, I cleaned my valves in an ultrasonic cleaner using acetone and heat. It certainly improved them but not to what they should be. I will try the method you posted. Failing that I will jump on Aliexpress.
    Aug 2011
    4,779
    Hi Baron,
    I have boiled the out of these valves and injected/forced acetone and turps through them and boiled again. Tomorrow I will inject/force brake clean through them and then re-boil the crap out of them. It gets to the stage where it no longer becomes ecconomical to try anything more. I can purchase a set of six for $US13 (including delivery) from Aliexpress. Only reason I persevere is cause I hate throwing stuff out AND I like trying stuff...
    I will report back tomorrow...
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,541
    I bought some replacements some time ago for my lathe but never got to use them as they are a US thread and the lathe fittings are British. Just something to watch for.
    Could not find anyone selling metering valves with a BSP thread at the time.
    Aug 2011
    4,779
    Yea, mine are M8x1. Everything on this mill is metric. The zerk lube fittings on the knee and knee leadscrew are M8x1.25 which makes it a PITA if I want to add them into the lube system.
    Dec 2013
    56
    1,416
    Hi Baron,
    In the AliExpress app, if you go to settings you can select what country your from and the prices show in Australian dollars, takes the guess work out of converting it from US
    Using Tapatalk
    Aug 2011
    4,779
    Thanks Dave.
    Well, after another treatment of boiling soapy water over the stove, then another ultrasonic cleaning and finally some flushing with brake cleaner using some extra pressure from an air compressor, I finally got a result that I'm happy with.
    They all seem to flow roughly the same amount of oil, so happy with that too.
    For anyone with an expensive machine or a machine that does a lot of work, I would not suggest this, just buy new. This is because ultimately, once they are installed, it's difficult to know if they stop working.
    For anyone who doesn't mind spending some time in between other stuff, or can t find the exact same thread or fitting or can't be bothered waiting 4 weeks for delivery, its well worth a go.
  1. Local supplier of one-shot lube parts?
    By StrayAlien in forum METALWORK GENERAL
    Last Post: 15th May 2018, 11:34 PM
  2. shot peening
    By morrisman in forum AUTO RESTORATION
    Last Post: 23rd Dec 2017, 10:01 AM
  3. One shot
    By sossity in forum METALWORK GENERAL
    Last Post: 23rd Dec 2016, 10:10 AM
  4. One shot oiler
    By Oldneweng in forum METALWORK GENERAL
    Last Post: 15th Jan 2016, 10:17 AM
  5. One shot lube systems for Mills and Lathes
    By markjaffa in forum METALWORK GENERAL
    Last Post: 6th Jan 2011, 12:49 AM
