Page 1 of 2 12 LastLast
Results 1 to 15 of 26
    Sep 2004
    Dardanup W.A.
    72
    331
    Default Chuck back plate
    Lathe 4 jaw chuck rear.jpgThis chuck has been machined with the two surfaces shown by the green arrows, level with each other.
    As it is impossible to source a cast iron back plate, or a suitable blank, I have started fabricating one, and I though it might be an idea to cut a few thou relief in the back plate surface, to make one of these two surfaces, the contact surface, rather than have both as contact surfaces, and I am leaning towards the outer.
    Good idea, bad idea, doesn't matter??
    Nov 2010
    Frankston south
    102
    Not sure how big the chuck is but most of the ones I have seen only use the smaller diameter
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Wouldn't worry about touching the Outside face of the chuck, when the backing plate is made it should have a diameter about an inch bigger than the mounting holes PCD.
    6,480
    I agree ! Don't worry about the outer edge. All the support should be in the centre part.
    FWIW I've seen a cast iron steam pipe flange used as a chuck backplate !
    Sep 2004
    Dardanup W.A.
    72
    331
    Well I wish I had asked a question BEFORE I bought and started machining a 210mm diameter piece of carbon steel, based on what the guy that sold me the chuck (200mm chuck) said.
    Too late now, so it will be 200mm diam. back plate....too much work to make it smaller, so I'll shave a couple of thou off the outer edge of the plate
    BaronJ, the flange would have had to be around 40+mm thick to provide the 24mm snout that goes over the spindle to the register, and even if I could have found on that thick, it would have been a LOT of machining to form the snout.
    6,480
    Hi Phill,
    In that case I wouldn't bother. A slight gap might make it ring !
    Sep 2004
    Dardanup W.A.
    72
    331
    Hi Phill,
    Thanks for that advice. It would be very annoying if it did ring.
    Jun 2007
    sydney ( st marys )
    64
    4,890
    Pity you didn't know what was really required as you could of sourced a piece of cast to suit.
    Sep 2004
    Dardanup W.A.
    72
    331
    That would have been nice
    Gotta love hindsight.
    Sep 2004
    Dardanup W.A.
    72
    331
    New chuck finally mounted.
    In the end I had to machine down the backplate to the smaller diameter simply because when it was assembled the unit was too heavy for me to lift onto the spindle with any control. It took a fair amount of time, and produced two 25 litre bins full of steel wool, but well worth it in the end.
    Aug 2019
    Revesby - Sydney Australia
    57
    1,196
    50 litres of steel wool?
    You will have the cleanest pots in Dardanup!
    Sep 2004
    Dardanup W.A.
    72
    331
    Quote Originally Posted by nigelpearson View Post
    Went straight in the bin. High tensile springs, all with rough edges all knotted together amounts to a real nightmare to clean up.
    I tried the vacuum cleaner, blocked the hose in no time, and lots of time to get the damned things out, then a broom, but they clung onto the broom bristles like magnets, so in the end it was pick up by hand and buy a dedicated shed broom for the smaller bits.
    In the end I was sooooo glad to see them going down the street in the truck
    6,480
    Hi Phil, Guys,
    You need a magnetic wand ! Unfortunately it doesn't do anything for brass or aluminium.
    I made mine from magnets salvaged from hard disc drives. Saves a lot of grief blocking up the wife’s vac.
    Sep 2004
    Dardanup W.A.
    72
    331
    Hi Phil, Guys,
    Sounds like a good idea, more info required
  15. #15
    Nov 2017
    Geelong, Australia
    57
    2,672
    Quote Originally Posted by ptrott View Post
    As the priest said to the actress....
    Mine is probably bigger than most but take a look:
    Outer is 50mm pvc with a cap on the end and a flange about 250mm back from the end
    Inner is 40mm pvc pipe with a large magnet stuck in the end
    In use you slide the inner all the way down, poke it at your dwarf to pick it up, take it to the bin and withdraw the inner.
    Swarf falls off the end or follows the magnet up until it hits the flange and then falls off.
    Simple
  1. Lathe chuck back plate
    By naijin in forum METALWORK GENERAL
    Last Post: 30th Aug 2018, 12:35 AM
  2. hercus ,qualos lathe face plate and chuck back plates
    By KBs PensNmore in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 7th May 2017, 02:13 PM
  3. spare D-4 back plate for 8" chuck
    By thorens in forum METALWORK GENERAL
    Last Post: 26th Nov 2013, 09:08 PM
  4. Chuck back plate
    Last Post: 15th Dec 2011, 07:17 PM
  5. chuck back plate thread
    By tanii51 in forum THE HERCUS AREA
    Last Post: 10th Jun 2011, 11:36 PM
