Results 1 to 4 of 4
1st Dec 2019, 06:09 PM #1Most Valued Member
- 70
- 1,514
Milling work needed on a piece of PFC
I have this piece of PFC which is destined to be a new bench drill table. It's 150 x 75 x 200 long. What I need is the top milled flat and the sides milled square to the top. Also need a mounting hole counterbored to mount it. Has a 12mm hole which needs a 25mm counterbore. Anyone on Brisbane north side that could do it. Also willing to post elsewhere if needed. Will pay to have this done.
Nev.
1st Dec 2019, 07:01 PM #2Most Valued Member
Hi Nev, any chance of a pic and a sketch of what you're proposing to do, PLEASE.
From what I can gather, where you're wanting the counterbores, is only about 6-8mm thick?
Not that I'm able to do the job, but curious about your request.
1st Dec 2019, 08:01 PM #3Most Valued Member
- 70
- 1,514
Will post a pic or two when I can. Counterbore needs to be only 3.5mm deep. PFC is 9mm. Probably around 7.5mm after milling.
Nev.
1st Dec 2019, 08:11 PM #4Most Valued Member
- 4,890
If you don't find someone local I could do it.
Small Milling Machine vice needed
By ml018 in forum WANTED TO BUYReplies: 8Last Post: 6th Dec 2018, 10:12 PM -
Cincinnati milling manual needed
By morrisman in forum METALWORK GENERALReplies: 2Last Post: 15th Dec 2015, 02:54 PM -
another outdoor piece
By Corgan in forum METALWORK GENERALReplies: 5Last Post: 3rd Sep 2011, 06:56 PM -
Interesting piece of maching work
By Woodlee in forum METALWORK GENERALReplies: 1Last Post: 19th Mar 2009, 10:17 AM -
Asking for someone to produce a piece of work - acceptable?
By Manaz in forum FORUMS INFO, HELP, DISCUSSION & FEEDBACKReplies: 3Last Post: 7th Oct 2007, 06:48 PM
