Results 16 to 17 of 17
Thread: Small Lathe Lifting
2nd Dec 2019, 11:34 PM #16Novice
- Nov 2019
- Perth Australia
- 16
3rd Dec 2019, 01:15 PM #17Senior Member
- Apr 2008
- 269
Opti lathe
Bought the same lathe as you Rumble, I made up a device out of 5mm RHS, welded two bit of rod underneath and drilled a hole through the center, bolted that close up near the headstock, the two bit of rod welded on either end stops the sling from slipping off when lifting with a engine crane, even with the tail stock moved to the far end, the headstock is out of balance when lifting, ended up using a com-a-long to balance out the sagging weight of the headstock, all went well.
DD
Adding a DRO to a small lathe?
By Pete F in forum METALWORK GENERALReplies: 8Last Post: 5th Oct 2014, 09:59 PM -
Lifting Lathe
By BigStick in forum METALWORK GENERALReplies: 13Last Post: 31st Mar 2012, 03:27 PM -
safe lifting points of hafco 960b lathe
By lather in forum METALWORK GENERALReplies: 35Last Post: 16th Aug 2010, 01:29 AM -
Lifting a Lathe
By Sterob in forum METALWORK GENERALReplies: 7Last Post: 29th Apr 2010, 11:22 PM -
