Results 1 to 5 of 5
    Nov 2019
    Brisbane
    69
    452
    Default More shaper work and Clarkson grinder.
    SAM_0550.jpgSAM_0549.jpg Just a short note in my saga with the T & C grinder. The pics show the finished sub plate, except de burring. I can never get the work head where I need it. It's either too close or too far from the wheel. This plate allows me to mount it where convenient. The plate can be mounted as in the pic or at 90 deg. Odd spacing of the slots prevent the holes not lining up. I've also shown the spacer plates needed to go over the alignment keys of the workhead and centres.
    The hot rolled 150mm plate was a horrible shape to begin with.
    More to come.
    BC
    Oct 2010
    melbourne, laverton
    1,910
    Default beautiful
    hi mate that looks great. How did you hold it while you cut the slots?
    Nov 2019
    Brisbane
    69
    452
    Quote Originally Posted by azzrock View Post
    Hi from Bernie.
    It was a dodgy setup. A piece of 100 X 20mm flat bar held in the mill vice, then put the plate on top. Held down with 2 cant twist em's from the side. The work did get loose when it all got hot. Twice in fact. The edges were cleaned up on the shaper.
    BC
    Aug 2011
    4,779
    The finish on those plates is certainly very nice.
    Nov 2019
    Brisbane
    69
    452
    Default Better finish.
    Hi from Bc.
    A much better finish can be achieved with a shaving tool. I just didn't have the time to do another pass. For fine cuts to improve accuracy or finish I lock the tool slide, then raise the table against a dial indicator. Shaving tools can take 0.5 thou reliably without tearing the surface. Depends on the steel of course. Stoning the tool maker a big difference.
    BC
  1. Shaper work 2. The tool holder
    By steamloco1954 in forum METALWORK GENERAL
    Last Post: 26th Nov 2019, 11:38 AM
  2. Shaper work
    Last Post: 26th Nov 2019, 08:39 AM
  3. Work Zone Grinder Fix
    By wheelinround in forum METALWORK GENERAL
    Last Post: 10th Nov 2013, 04:52 PM
  4. Surface grinder does Cylindrical Work
    By Abratool in forum METALWORK GENERAL
    Last Post: 3rd Mar 2012, 10:21 PM
  5. Clarkson chucks
    By Stustoys in forum METALWORK GENERAL
    Last Post: 26th Dec 2010, 09:41 PM
