Results 16 to 19 of 19
Thread: deep hole drilling in Acetal
30th Nov 2019, 09:45 PM #16
Here is a link I found helpful.
http://www.dotmar.com.au/images/mach...structions.pdf
I read elswhere, (and now can't find where that was) that the max temp was 125 Celcius and beyond that shrinks inwards.
I found that the drilled 8mm hole shrinks to grab the 8mm range rod shafts, despite use of coolant. Mind you, I knew not about "pecking" at this stage.
I hope it helps.
30th Nov 2019, 10:57 PM #17
At the time I was drilling long holes in PTFE (Teflon rod) It being a very soft and flexible material that came in long 10 foot lengths, it was very difficult to maintain a straight precise diameter hole. I also had the problem that the outside diameter had to be controlled to within a few thou over the 8" inch length.
I solved both problems by turning the whole ten foot lengths of Teflon rod down to the correct diameter, I forget now what that diameter was, but the rod came in to me at 1/2" diameter. Then cutting the 8" inch lengths on a chop saw.
When it came to drilling the bore, the Teflon rod after turning to size was pressed into the heated pre-machined aluminium housing and placed into cold water. This caused the alloy to shrink and grip the Teflon rod. It couldn't move when that was done. You cannot use adhesives with Teflon, it doesn't stick to it. The aluminium housing was then spun in the lathe for drilling. I could easily maintain a straight hole within a thou or two.
Afterwards a turned brass rod was pressed into the bore after being threaded at both ends, then assembly took place.
I made a couple of hundred of these items. However all the jigs and tools were passed on to the company contracting me to do this work, so I'm sorry there are no pictures that I can show !Best Regards:
1st Dec 2019, 11:00 AM #18Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
1st Jan 2020, 08:44 PM #19Novice
- Nov 2019
- NE Victoria
- 75
- 14
Help - drilling deep holes in steel
By nadroj in forum METALWORK GENERALReplies: 12Last Post: 7th Jun 2019, 08:48 AM -
Deep hole drilling. MT5 - ER32
By Stustoys in forum METALWORK GENERALReplies: 46Last Post: 16th Jul 2013, 11:28 PM -
Drilling a hole in a tight spot?
By mjmurray in forum METALWORK GENERALReplies: 6Last Post: 20th Jan 2013, 08:31 AM -
Drilling square hole
By kraits in forum METALWORK GENERALReplies: 9Last Post: 18th Oct 2011, 01:12 PM -
Drilling Hole In Angle Iron
By echnidna in forum METALWORK GENERALReplies: 13Last Post: 15th Jan 2009, 09:53 PM
