Results 1 to 10 of 10
Thread: Jabsco Pumps.
28th Nov 2019, 09:38 PM #1Senior Member
- Jun 2005
- Townsville, Tropical Nth Qld.
- 225
Jabsco Pumps.
Hi guys, I have an old Parkanson Power Hacksaw with a Jabsco Impeller pump for the coolant supply and the V belt keeps stuffing up. It is a major job to clean and readjust the pump as the belt stretches or wears. I am thinking of making a new drive using a toothed belt. If so the pump will have to spin a lot faster. I have searched the Net and cannot find any reference to how fast they can be run. Does anyone have any ideas? All help will be appreciated.
Rgds,
Crocy
28th Nov 2019, 09:56 PM #2Member
- Nov 2015
- Brisbane Australia
- 85
Here is a link to a Fynspray impeller pump, I think they are similar in operation.
I worked for a company 30 years ago and we sold Fynspray pumps.
From what I read they the ball bearing model goes to 2400 RPM and the plain bearing model goes to 1750rpm
https://www.jpwmarine.com.au/fynspra...earing-rwb2670
https://www.whitestarproducts.co.nz/...ller/ws36.html
29th Nov 2019, 12:36 AM #3Senior Member
- Perth, Western Australia
- 67
- 362
What speed is it spinning at now?
I ran a plain shaft, rubber impelled Jacobs for about 10 years on my parts washer. Changed a few impellers but don`t remember changing the belt. It was spinning at about 300-400 rpm.
29th Nov 2019, 03:21 AM #4
Hi Crocky,
I'd check and make sure that the bearings are not tight ! They can wear and get tight without seizing up. That will cause belt wear, also you could fit an elastic type belt like they used to use on twin tub washing machines. They used to run for years until they stretched and slipped.Best Regards:
29th Nov 2019, 07:26 AM #5Most Valued Member
- 2,651
I can vouch for using an elastic belt as Baron suggests. I've also got a Parkanson PH and that's what I've got on mine.
I used the red hollow poly belt that has a barbed aluminium joiner. Works well.
29th Nov 2019, 09:22 PM #6Senior Member
- Jun 2005
- 225
29th Nov 2019, 09:37 PM #7Senior Member
- Jun 2005
- 225
I have no idea what has gone wrong with the multi quote, but it will only let me do 3 at a time,
BTS, It is only doing about 70 RPM, so I can now really step it up, I will just add a relief bleed valve for the increased flow.
Baron J, I only replaced the impeller about 9 months ago, the pump was spinning OK then.
Baron and Steve, I will go to my supplier and check out if he has that material.
For everyone, Dad used to have no end of problems with the belt slipping as the oil from the main shaft used to leak through to the pulleys and get onto the belt. About 2 years ago, I bought an oil seal to suit the main shaft, stripped the machine right down and made a counterbore to insert the oil seal in the housing, loctite'd it in and it has performed faultlessly since, until the impeller died of old age.
Thanks again,
Rgds,
Crocy.
29th Nov 2019, 09:56 PM #8Most Valued Member
- 2,651
Crocy, if let me know roughly the length you need - I might be able to save you a couple of dollars.
30th Nov 2019, 05:33 PM #9Most Valued Member
- 4,255
Dad ran one on direct drive from 1440 rpm motor for eons before he sold it. Just used a bit of heavy duty hose and couple hose clamps to act as a coupling.
30th Nov 2019, 10:08 PM #10Senior Member
- 67
- 362
Must have been one of those subconscious things but I was looking through some boxes of stuff for something unrelated and came across these. Thought I had given most away but apparently not.
I need to go through and make a list of what I have got.
What oil for enerpac hydraulic pumps?
By Com_VC in forum METALWORK GENERALReplies: 10Last Post: 27th Jul 2019, 04:47 PM -
FREE: Compressor pumps and motors
By lamestllama in forum METALWORK - Machinery, Equipment, MARKETReplies: 16Last Post: 7th Apr 2019, 12:33 AM -
hares & forbes coolant pumps?
By Com_VC in forum METALWORK GENERALReplies: 23Last Post: 2nd Apr 2011, 06:54 PM -
Coolant pumps in reverse
By Stustoys in forum METALWORK GENERALReplies: 31Last Post: 7th Aug 2010, 10:50 AM
