Results 1 to 4 of 4
Thread: Shaper work 2. The tool holder
26th Nov 2019, 10:50 AM #1Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Here are the pics of 2 tool holders. Pic 2 is of the smaller unit. The cap has a slotted hole so it can adjust to the tool bit size. A ramp on one side and square cut groove on other side to capture tool bit. I run it backwards in the shaper to reduce chatter. That puts the tool behind the centre of pull. I have crashed the bit into a job and stalled the shaper. By accident. No damage to bit or holder. It's an 18" shaper. Only problem so far is in deep slots. The fat holder head makes it hard to get low in the slot. I'm buying some bigger bits next order.
BC
26th Nov 2019, 11:06 AM #2Most Valued Member
- 2,651
Thanks for the detail Steamloco.
Does the clamp piece rotate in relation to the main holder body - ie can you set the tool bit on an angle to make it a left/right tool or does it need to be in line with the body?
26th Nov 2019, 11:24 AM #3Member
- Nov 2019
- AU
- 52
Thanks for the much more detailed run down on the tool holder.
Sent from my SM-G930F using Tapatalk
26th Nov 2019, 11:38 AM #4Senior Member
- Nov 2019
- Brisbane
- 69
- 452
Shaper work
By steamloco1954 in forum METALWORK GENERALReplies: 5Last Post: 26th Nov 2019, 08:39 AM -
Shaper tool holder's to swap.
By lamestllama in forum WANTED TO BUYReplies: 3Last Post: 7th Aug 2017, 12:12 PM -
Tool Holder for HBM
By Mike4 in forum METALWORK GENERALReplies: 6Last Post: 20th Jan 2016, 10:17 AM -
Drill pad / work holder
By teesider61 in forum METALWORK GENERALReplies: 12Last Post: 25th Dec 2015, 08:05 AM -
Tool holder I.D. ?????
By morrisman in forum METALWORK GENERALReplies: 16Last Post: 16th May 2013, 08:19 AM
