Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
  1. #16
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,559
    ...but when a mate of mine retired he gave me 2 new m12 gun taps, along with some other used and new taps...i think these are suitable are they not?
    I think so, yes. Spiral taps push the chips out the top of the hole and gun taps push them through. The gun taps should be fine if the holes are through.
    Remember the trefolex/ lube too.
  2. #17
    Jul 2006
    Athelstone, SA 5076
    4,258
    Okay in to do on the mill....or should i use dp?
  3. #18
    Oct 2011
    59
    6,559
    Better in a drill press - the quill is the important part. But - an M12 tap is a sturdy beast. Perhaps try it in a soft material (AL?) and see how it goes.
  4. #19
    Aug 2006
    1,106
    Never seen one used with a die before only taps, did you make that up or is this fairly common?
  5. #20
    Oct 2008
    N.W.Tasmania
    1,407
    [QUOTE=eskimo;1959419]
    I have a M12 spiral tap you can borrow. You should not use a straight flute tap as there is a risk it will jam with the chips in the flutes.
    Use is simple - mount it in the drill press and use it as you would a drill. When you are at depth, release the handle and this should put the tapping head in reverse, where it will back out of the hole.
    And repeat...
    Michael[/QUOTe
    Tks Michael...but when a mate of mine retired he gave me 2 new m12 gun taps, along with some other used and new taps...i think these are suitable are they not?
    They should be ok if the holes are through holes, but if they are blind holes you will need a spiral flute tap.
    Sorry but didn't notice that there was a second page of postings, and that I was waaaay two late with my post.
    Last edited by Ropetangler; 2nd Dec 2019 at 10:00 PM. Reason: Didn't see the second page of postings.
  6. #21
    Jul 2006
    Athelstone, SA 5076
    4,258
    Used the tapping chuck with 10mm spiral flute tap.
    The waldown has a VSD so I started off slow.
    motor kept stalling.....so changed pulley ratio to get extra torque with less spindle rpm.
    This tapping chuck is certainly going to get used more often...it worked a treat....
  7. #22
    Jul 2006
    Athelstone, SA 5076
    4,258
    Finished the plate.
    [ATTACH=CONFIG]383569[/ATTAC
    Hardest part was tapping all the holes...after all i had to move the table 50mm in x&y axis for every hole. Gee these tapping chucks are bloody great!!!!.
  8. #23
    6,473
    I have a small 1/4" inch capacity "Archer" tapping chuck that I managed to jam and broke one of the internal gear shafts. Its been hidden in a box for a good number of years. I'll have to dig it out and repair it. I gave away its big brother with a 3 MT arbour and 5/8" capacity, having never used it. I had a die holder for the big one, but I might have given that away as well.
  1. Piper No.2 Reversible Tapping Chuck
    By thorens in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 21st Mar 2016, 02:39 PM
  2. Piper Tapping Chuck
    Last Post: 2nd Mar 2016, 10:53 PM
  3. Piper No.2 Reversible Tapping Chuck
    By Anorak Bob in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 20th Feb 2016, 10:11 PM
  4. piper tapping chuck questions.
    By thorens in forum METALWORK GENERAL
    Last Post: 20th Dec 2013, 12:35 AM
  5. SOLD: Piper Reversible Tapping Chuck
    By SurfinNev in forum METALWORK - Machinery, Equipment, MARKET
    Last Post: 30th Jun 2012, 05:12 PM
