Results 1 to 15 of 23
Thread: Piper #2 tapping chuck
25th Nov 2019, 03:39 PM #1Most Valued Member
- 4,258
Making a fixture plate for the RT. Going to drill around m12 holes.
The piper doez not appear to be auto reversing and i cant see any way of controlling torque
Do I need any special tap?
What else should I know ....other than sticking up the spindle and start threading?
25th Nov 2019, 03:42 PM #2Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
25th Nov 2019, 04:30 PM #3Most Valued Member
- 4,258
25th Nov 2019, 04:33 PM #4Most Valued Member
- Oct 2010
- 1,910
piper
Is there 2 holes for a pin spanner that wind the top in and out?
aaron
25th Nov 2019, 04:52 PM #5Most Valued Member
- 4,258
Not that I can see
25th Nov 2019, 04:56 PM #6Most Valued Member
- Oct 2010
- 1,910
check
it looks different from the one i had. what are the other 2 holes lower down for?
25th Nov 2019, 05:05 PM #7Most Valued Member
- Oct 2010
- 1,910
maybe
does it reverse when you raise the down feed?
25th Nov 2019, 05:15 PM #8Most Valued Member
- 4,258
25th Nov 2019, 05:25 PM #9Most Valued Member
- Oct 2010
- 1,910
taps
I think the spiral type taps are more suited.
twice as fast sort of makes seance because its not cutting.
aaron
25th Nov 2019, 05:41 PM #10Most Valued Member
- 4,258
25th Nov 2019, 05:51 PM #11Philomath in training
- 6,563
I have a M12 spiral tap you can borrow. You should not use a straight flute tap as there is a risk it will jam with the chips in the flutes.
Use is simple - mount it in the drill press and use it as you would a drill. When you are at depth, release the handle and this should put the tapping head in reverse, where it will back out of the hole.
And repeat...
25th Nov 2019, 05:52 PM #12Most Valued Member
- 2,673
25th Nov 2019, 06:13 PM #13Most Valued Member
- 4,258
[QUOTE=Michael G;1959417]I have a M12 spiral tap you can borrow. You should not use a straight flute tap as there is a risk it will jam with the chips in the flutes.
And repeat...
Michael[/QUOTe
Tks Michael...but when a mate of mine retired he gave me 2 new m12 gun taps, along with some other used and new taps...i think these are suitable are they not?
25th Nov 2019, 06:15 PM #14Most Valued Member
- 4,258
Is allright to do in the mill on lowest speed ....would torque be too high?
Or would DP on low vfd speed be better
Oh, the plate is steel and is 16mm thick...any problems?
25th Nov 2019, 06:18 PM #15Pink 10EE owner
- 6,218
Here is mine. https://www.youtube.com/watch?v=ucMHk-wJdbQ
Piper No.2 Reversible Tapping Chuck
By thorens in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 21st Mar 2016, 02:39 PM -
Piper Tapping Chuck
By Anorak Bob in forum METALWORK GENERALReplies: 8Last Post: 2nd Mar 2016, 10:53 PM -
By Anorak Bob in forum METALWORK - Machinery, Equipment, MARKETReplies: 7Last Post: 20th Feb 2016, 10:11 PM -
piper tapping chuck questions.
By thorens in forum METALWORK GENERALReplies: 6Last Post: 20th Dec 2013, 12:35 AM -
SOLD: Piper Reversible Tapping Chuck
By SurfinNev in forum METALWORK - Machinery, Equipment, MARKETReplies: 5Last Post: 30th Jun 2012, 05:12 PM
