Results 1 to 8 of 8
24th Nov 2019, 11:13 AM #1Senior Member
- Feb 2012
- Tamworth, NSW
- 202
ER or 5c collet chuck for small screw making I have read
Hi everyone
i have ave been looking at setting up a collet chuck in my Emco super 11 lathe and am looking for some advice please. I have read many previous posts which has lead me to the following summary.
ER collets have wider range of holding size per collet, were designed primarily for milling tool holding, grip along entire collet length and are generally for holding round stock.
5c collets were designed for work holding in lathes, have narrow holding size (need more collets to cover size range compared to ER), grip at front of collet, very good at holding short pieces, can buy inserts for square and hex bar, can bore own size collets and potentially less marking of surfaces when holding threads etc compared to ER (I’m not sure about this last one?).
I don’t have any collets or a milling machine at the moment so am starting from scratch. I intend to make small screws (2mm thread) and small barrel pivots (4-5mm) as well as bolt action pens (probably around 10mm diameter). With my intended uses in mind is there a particular reason that you feel one collet type would be better for me over the other?
I was pretty set set on going ER-32 as it seems a popular and easy route but after a fair bit of research I have started to lean towards 5c. Both are readily available and price in setting up for each not too dissimilar (not enough to persuade me one way or another).
I have a Bison 3 jaw and an Emco 4 jaw chuck already that came with the lathe.
In my shoes what would you do?
Ian
24th Nov 2019, 11:23 AM #2Most Valued Member
- Jul 2016
- 35
- 1,522
I would probably go 5c. They are better at holding short items er does not grip well under 30% of their length. You can also put dead length stops in easily. I would go with a drawtube arrangement if possible not a scroll type chuck. Although they will do in a pinch.
24th Nov 2019, 12:24 PM #3Senior Member
- Aug 2007
- 292
I have a 5C chuck and think it would be better for your needs. If you thread one of the machinable collets it will grip the threads without damage it to work on the head. They are designed to take a depth stop which for some work is great. Parting off multiple pieces to length repeatedly for example. If you can justify the cost one of the Atlas hand wheel speed collet chucks you'll be in heaven. No chuck keys to fiddle with. Sure wish I had gotten it for my lathe instead of the Bison (a good chuck itself). A drawbar collet holder is even faster but can be hard to fit some lathes. https://www.grizzly.com/products/Atl...in-Back/T10353
Pete
24th Nov 2019, 12:28 PM #4Gear expert in training
- 34
- 1,075
24th Nov 2019, 01:24 PM #5Diamond Member
- Feb 2013
- Laidley, SE Qld
- 1,038
The big advantage of 5C over ER for lathe work is speed of work change over. Not important for onesy twosy work but if you are doing small runs the time savings mount up.
With a rear collet closer, work swapping in a 5C can be done in seconds rather than maybe a minute for an ER32 collet. Not that you need ER32 for the sizes of items you mention, ER16 or maybe ER11 will suffice.
24th Nov 2019, 02:07 PM #6Senior Member
- Feb 2012
- Tamworth, NSW
- 202
Thank you for the excellent advice everyone. An atlas would be great but not the kind of money I am looking to spend at the moment. In all honesty I’m likely to play AliExpress roulette with the upcoming Black Friday sale and purchase a key closing 5c chuck and mount via backplate ah-la Stefan Gottswinter.
Other than speed of changing collets is there other advantages of a drawbar setup?
24th Nov 2019, 10:15 PM #7Member
- Nov 2015
- Brisbane Australia
- 85
Not that I am very smart or knowledgeable about using lathes but one thing I have seen good about collets is the fact that it has a drawbar, from my limited knowledge I would think it would add/enable more support than a thin part in a 35 or 40mm diameter lathe headstock.
24th Nov 2019, 10:50 PM #8Most Valued Member
- Jul 2016
- 35
- 1,522
Big advantage is the its all supported inside the spindle with a drawbar setup, less overhang means more rigid.
ER Collet Chuck
By familyguy in forum METALWORK PROJECTSReplies: 2Last Post: 1st Apr 2019, 10:25 AM -
ER 32 or ER 40 collet chuck
By welder in forum METALWORK GENERALReplies: 11Last Post: 4th Apr 2011, 01:58 AM -
Making a collet chuck
By Bryan in forum METALWORK GENERALReplies: 21Last Post: 1st Aug 2010, 03:51 PM -
Cracked chuck screw
By phelum in forum METALWORK GENERALReplies: 21Last Post: 18th Jul 2010, 11:20 PM -
Fastening cables to a small eye screw
By smittydd in forum METALWORK GENERALReplies: 5Last Post: 11th Apr 2010, 10:02 PM
