Results 1 to 10 of 10
Thread: Replacement bench grinder parts
17th Nov 2019, 08:37 PM #1
I have an old GMF 8" /200mm bench grinder. It's a 1978 vintage, used to belong to a family member.
I'm missing one of the flange washers for the disc.
Anyone know a good place to source one?
I'm also looking to ID the arbor thread size...
I've measured the shaft OD to 5/8" which is needed for the flange washer. The threads are slightly less than this, and have a metric 1.5 pitch, to the best of my knowledge using my thread gauge set.
Were these commonly 16mm x 1.5, or a 5/8"-18 tpi more commonly?
17th Nov 2019, 09:10 PM #2Most Valued Member
- 5,942
I've a stack of the large flanged washers, pretty sure there's a 5/8" one in there.
Will try to remember to look tomorrow.
KrynLast edited by KBs PensNmore; 17th Nov 2019 at 11:09 PM. Reason: added Flanged
17th Nov 2019, 09:26 PM #3Member: Blue and white apron brigade
- 7,182
You shouldn’t use any old washer. The flanges for these grinders are quite large -almost 100 mm in diameter and they have a slightly raised inner rim of the flange to ensure max grip on the wheels. And the pressure points of the flanges must also match on either side of the wheel. For max grip something like thick paper or card can be used in between the wheel and the flange. I’ve found Lino makes for excellent grip and helps prevent the wheel loosening.
I have turned up a number of these flanges as they are quite easy to turn up. Maybe someone near you with a lathe can make one that matches your existing one?
17th Nov 2019, 09:54 PM #4
Hi Comander, beware which side of the grinder you need the nut for ! One side is a left hand thread
17th Nov 2019, 10:02 PM #5
True 5/8" is 4.9 thousands of an inch smaller than true 16mm. If you have the left and right nuts for the arbor and just need the washer, I doubt that you would have issues aiming for a close 16mm hole, the less than 0.005" variation would not be much of an issue for 5/8".
On the other hand, if you need the nut as well, you need to determine whether you need the LH or RH thread, as well as the diameter and pitch for the nut.I used to be an engineer, I'm not an engineer any more, but on the really good days I can remember when I was.
18th Nov 2019, 06:44 AM #6
Thanks for the advice, the mythical beast i've been searching the old man's shed for yesterday looks like this:
Overall diameter is 3", 5/8" centre dia.
The flanges are not threaded, there is a nut as a secondary fastening means, via comperssion on the flange. So I do not believe the flanges are LH or RH specific.
I don't own a lathe, so I would be happy to pay for the service of a matching pair, or purchase a pair if someone has an abundance of spares they want to get rid of.
It's a bit of a bugger having lost them, the grinder was my grandfather's, my father had it collecting dust for 25 years before I asked if he was willing to let me give it a good home.
18th Nov 2019, 08:31 AM #7Member: Blue and white apron brigade
- 7,182
Yep they are the ones I 'm referring to.
I had a spare pair of these but unfortunately I gave them to Anorak Bob earlier this year. Hopefully someone else will have spares.
18th Nov 2019, 07:56 PM #8Senior Member
- 112
18th Nov 2019, 08:36 PM #9
Picked up a m16 x 1.5 nut today. Fits perfectly.
Sent from my iPad using Tapatalk
21st Nov 2019, 09:36 PM #10
Have tasked a local big box tool supplier (definitely not the big green shed, but a red shed) to source some flange washers... They tell me they will enquire about spares through Abbot and Ashby... will see if it's something they follow up on.
Gave them the dimensions of a 3" OD, with a 5/8" ID. I might be skeptical, but the young bloke wrote my query details down on a scrap of paper. I hope I am surprised.
GMF grinder bearing replacement
By monchochos in forum METALWORK GENERALReplies: 22Last Post: 3rd May 2019, 12:18 PM -
Bench grinder capacitor replacement
By Grahame Collins in forum ELECTRICALSReplies: 12Last Post: 13th Jul 2017, 10:09 PM -
T and C Grinder Workhead - Drive Motor Replacement.
By Anorak Bob in forum METALWORK GENERALReplies: 11Last Post: 18th Jun 2014, 07:46 AM -
bench top for a bench grinder
By wodstok in forum METALWORK GENERALReplies: 1Last Post: 24th Jan 2011, 03:04 PM
