Results 1 to 15 of 17
Thread: Thomas 4 x 4 tyre pump
13th Nov 2019, 08:09 PM #1Senior Member
- May 2012
- Vermont 3133 Victoria
- 248
Hi Gang,
I have this Thomas pump which is need of some work. I have stripped it down and am replacing the bearings. One was marked as 6102Z which I ordered from RS components. didn't think to check the dimensions. So it seems 6102Z is a 12mm ID I need 8mm ID.? Bearing I need is is 32x10x8. Also the piston seal is a plastic type cup, should I just give it a light smear of grease.
Bruce
13th Nov 2019, 08:41 PM #2Philomath in training
I think there have been a few mix ups here
A 6201 is OD32, ID12 and 10 high. I can't find a SKF listing for a 6102 Z or a 610 2Z (the Z meaning grease shields from memory)
I also tried selecting a bearing of OD32, ID8 and 10 high and that came up empty as well.
If you really need 32x10x8 then you may have to make up a sleeve for the bearing you have been given.
13th Nov 2019, 08:56 PM #3
HI Bruce, Guys,
Like Michael, I have been unable to fine anything for that bearing number ! I do recall that quite some time ago there was a range of bearing numbers that was discontinued. I would have a wonder round to my local bearing supplier and ask them to help find the actual bearing that you want from the sizes. They will have cross reference guides that they use that are not generally made public.Best Regards:
13th Nov 2019, 08:57 PM #4China
- Dec 2005
- South Australia
- 1,657
If this is the same Thomas as made 4x4 winches ,they are known for using custom made components only available through them
13th Nov 2019, 08:57 PM #5Senior Member
- May 2012
- 248
Boy Now I think I might be dyslectic.
I just checked the number on the shield and it is 6201z, Hoover NSK. This pump unit is made in the USA. The bearing is definitely 32 OD x10 high x ID8 as measured.
13th Nov 2019, 08:58 PM #6Senior Member
- May 2012
- 248
Definitely no sleeve on the shaft.
13th Nov 2019, 09:01 PM #7
Bruce,
Bearing 6201 is a 12 mm bore ! 32 mm Diameter and 10 mm Thick !Best Regards:
13th Nov 2019, 09:19 PM #8Senior Member
- May 2012
- 248
Yep,
And 6201 is on the shield but the ID is 8mm with no sleeve, could it be an imperial size?20191113_211123.jpg20191113_211107.jpg
13th Nov 2019, 09:21 PM #9Senior Member
- May 2012
- 248
Yes I think so.
13th Nov 2019, 09:48 PM #10Pink 10EE owner
- 6,218
Just bush a 6201 bearing. Job done.
13th Nov 2019, 09:57 PM #11Senior Member
- May 2012
- 248
yep but the lathe is in rebuild.
13th Nov 2019, 10:50 PM #12Golden Member
- Sep 2008
- Riddells Creek, Vic.
- 838
Are you sure it is 8mm I/D Bruce, it could be a 6201 metric bearing with an imperial bore ie 5/16". What did you use to measure the bore?
Lex.
14th Nov 2019, 07:48 AM #13Senior Member
- May 2012
- 248
Hi Lex,
The shaft mic's as 8mm, can you get off the shelf 6201 metric bearing with an imperial bore of 5/16.
Bruce
14th Nov 2019, 11:00 AM #14Golden Member
- Sep 2008
- 838
I'm not sure about 5/16" Bruce, but I do know that you can get 1/2" and possibly other imperial sizes.
14th Nov 2019, 11:56 AM #15Senior Member
- May 2012
- 248
Turns out Bearing wholesales in Bayswater have 1 6201Z with an 8 mm bore so I will get it tomorrow.
Bruce
George Thomas' Universal Pillar Tool - Complete Set of Five Castings
By Anorak Bob in forum METALWORK - Machinery, Equipment, MARKETReplies: 2Last Post: 7th Nov 2018, 03:05 PM -
"Defiant" floor model no 80 Milling machine, Thomas herbert & Co, Sydney
By myworkshop97 in forum ANTIQUE AND VINTAGE MACHINERYReplies: 8Last Post: 6th Apr 2018, 08:33 PM -
Looking for a used/cheap 175/70-14 or a85/70-14 rally tyre
By jhovel in forum AUTO PARTS / Wanted, For Sale - HELPReplies: 0Last Post: 27th Sep 2017, 09:41 PM -
Washing machine pump as a coolant pump
By BobL in forum METALWORK GENERALReplies: 66Last Post: 9th Oct 2015, 09:25 PM -
Tyre Hammer
By Swarfmaker1 in forum THE SMITHYReplies: 3Last Post: 17th Jun 2015, 08:43 AM
