Results 1 to 15 of 23
29th Oct 2019, 01:44 PM #1Intermediate Member
- Sep 2016
- 27
Extend thread on a socket head bolt
Hello there -
My question is related to extending existing threads on socket head bolts - Allen Key bolts.
How do you clamp a socket head bolt into a 3 jaw chuck to cut the existing thread longer?
For example, I have a M8x50 bolt and the thread is only 20mm but I need 35mm thread.
I tried to hold it in a bench vice, but that’s not very good, I tried in a 3 jaw chuck on my lathe, but it does not run true and also does damage the head on the bolt. I tried to put some copper around the head of the bolt and also then tried the same with aluminium, but both attempts did not work very well. Any suggestions?
thanks heaps
29th Oct 2019, 02:03 PM #2Golden Member
- Jun 2005
- Helensburgh
- 618
29th Oct 2019, 02:35 PM #3Intermediate Member
- Sep 2016
- 27
29th Oct 2019, 03:17 PM #4Most Valued Member
- Jun 2012
- SA
- 1,649
You don't. You use a collet to hold it, but you don't have collets I expect, like 90% of lathe owners out there.
So your next best method is to get/make some vice jaw plates with a "V" cut into each face vertically and use those to grip the round head section of the bolt - tap the thread by hand with a die. You can get by with just one "V" plate and the original flat vice jaw in most cases.The worst that can happen is you will fail.
But at least you tried.
29th Oct 2019, 03:41 PM #5Intermediate Member
- Sep 2016
- 27
29th Oct 2019, 03:58 PM #6Member: Blue and white apron brigade
Make some small collets by putting a cut through a couple of nuts and screwing these onto the screw thread and hold the nuts in the 3 jaw, also repeated use of split does can ease the threading/cutting load
29th Oct 2019, 04:39 PM #7Golden Member
- Mar 2009
- 54
- 825
If its a grade 12.9 screw it's going to be hard to machine however you hold it and if you're using a die be careful not to chip the teeth.
Rather than mess around I would just buy a new cap screw with a full length thread, shouldn't be a problem for 50mm long.
Greg.
29th Oct 2019, 04:47 PM #8Golden Member
- Jun 2005
- Helensburgh
- 618
What size is the Key? Unless it is smaller than 4mm I can't see a cap screw rounding the head or key if they aren't Chinese crap. Button heads yes, they will strip but not cap screws using a good condition key. Just my experience over many years of using thousands of Allen heads. If you don't have a chuck and have a drill press with a Morse taper chuck, reove the chuck from the drill hold the flat of the morse taper shaft in a vise and use the chuck to hold the bolt.
CHRIS
29th Oct 2019, 05:13 PM #9Most Valued Member
- Healesville
- 2,129
justask have you tried griping one of the handles of your diestock in your vice, with soft jaws or 2 bits of wood, then
screw the cap screw into the die and cut the thread using an allen key and cutting oil or trefolex.
Whether that works or not depends on how hard the bolt is and how good your die is but it might be worth a shot.
cheers, shed
29th Oct 2019, 05:16 PM #10China
- Dec 2005
- South Australia
- 1,657
Some things are just not worth the bother just buy the correct bolts
29th Oct 2019, 07:09 PM #11Golden Member
- Jun 2005
- Helensburgh
- 618
29th Oct 2019, 07:54 PM #12Member: Blue and white apron brigade
I must be an odd one out as I tend to do this quite often.
One reason is, my stash of screws seems to be growing faster than I use them up and long ago ran out of storage space.
The screw stash comes from gear that came out of the skips at work, and where possible, for screws that are >50 mm long, in the past I've usually purchased boxes of screws with short threads as is much easier to add threads than to put the missing threads back on.
But the main reason is that as excellent and well priced as my specialist fastener supplier is, they are 25 minutes away (one way with no traffic - up to an hour or more with traffic) and open 7:30 am to 4 pm M-F.
So unless I need a multiple fasteners it is far quicker for me to add a couple of threads to an existing fastener or two.
I'm sure the same applies to an even greater extent for anyone in the country.
The times I usually don't do it is when screw strength is important
29th Oct 2019, 09:42 PM #13Senior Member
- Mar 2013
- Mt Pleasant SA
- 126
What's the fuss about? Did exactly what you want 5 days ago with a 65 y.o P&N carbon steel die .. I know coz I was there when my father bought it.
Aluminium angle protectors on the vice jaws, don't be frightened to tighten the vice you can't hurt the cap head if it's reasonable quality BUT take care to 'swallow' the head i.e. position the head down in the mid section of the jaws ( 5" Dawn vice). Use a GOOD cutting compound, I use the Bordo stuff that smells like 1950s hair oil. You can't get cap heads with more thread coz THAT is the specification .. no one makes cap head set screws(British terminology). GO FOR IT!
29th Oct 2019, 10:32 PM #14Member: Blue and white apron brigade
OP
I had a quick look in my stash.
As far as M6 caps go I have plenty of 25 mm that have 25mm of thread, Some that have 30 mm, and lots of CS socket heads with 32 mm of thread.
For M8s the longest threads are 30 mm.
30th Oct 2019, 01:31 AM #15
I don't understand why there is all this fuss about fully threaded cap head screws ! If I want to buy fully threaded ones, I just ask for them ! Admittedly they cost a little more but they are readily available, particularly if you want stainless steel ones.
Otherwise as has been said its easy enough to just add a few threads as needed. I just put a suitable die in the holder and clamp one handle in the vise and thread the screw in using a good fitting Allen key, I've even used my expensive "T" handle ones for smaller screws.Best Regards:
Countersunk socket head screws
By eskimo in forum METALWORK GENERALReplies: 19Last Post: 23rd Aug 2018, 11:05 AM -
Flat head socket screws
By neksmerj in forum METALWORK GENERALReplies: 12Last Post: 11th Jun 2015, 11:12 PM -
1" BSP as a nut & bolt thread.
By bob ward in forum METALWORK GENERALReplies: 2Last Post: 22nd Jul 2014, 03:29 PM -
socket head screw sets? Where for decent price?
By desbromilow in forum METALWORK GENERALReplies: 9Last Post: 24th Nov 2012, 07:34 AM -
american thread bolt 8-32 where?
By old_picker in forum METALWORK GENERALReplies: 6Last Post: 6th Aug 2011, 06:47 PM
