Results 1 to 3 of 3
Thread: Cutting #18 sheet steel
29th Oct 2019, 11:19 AM #1
Just wondering, I've never used a plasma cutter . If I was to cut #18 gauge sheet steel with a plasma would the edge finish be nice and clean/sharp ? Would the coating on the steel effect the cut edge finish ie zinc or whatever ? The other option is a electric nibbler but expensive to buy
29th Oct 2019, 11:54 AM #2Most Valued Member
- Sep 2010
- Lebrina
- 1,915
I've cut 1.2mm steel with a plasma cutter on many occasions with really good results. You really want a straight edge guide to do the best job as it is quite difficult to track accurately at high travel speeds without guides of some description, the good news being that plasma cutting guides can be very simple and even MDF can be used for templates.
Mill finish and Zincseal/Zincanneal suffer no ill effects from the plasma cutting and even Galvanised is minimally affected provided you don't slow down too much and burn the Galvanising. The cut produced has minimal dross on the back edge and a quick lick with a sharp cold chisel will knock off most of the dross, leaving a sharp, weldable edge.
Hope this answers your questions.
29th Oct 2019, 04:08 PM #3Member: Blue and white apron brigade
I’ve found nice dry compressed air can make a difference in the cleanliness of the cut.
29th Oct 2019, 04:16 PM #4Most Valued Member
- Sep 2010
- Lebrina
- 1,915
Where to buy very thin sheet steel
By springwater in forum METALWORK GENERALReplies: 12Last Post: 20th Dec 2012, 07:41 PM -
Perforated Steel Sheet
By Chris Parks in forum METALWORK GENERALReplies: 1Last Post: 17th Feb 2012, 03:26 PM -
Which Tool for cutting sheet metal
By squigs in forum METALWORK GENERALReplies: 16Last Post: 9th Aug 2011, 11:06 PM -
Steel Sheet or Plate
By Metal Head in forum METALWORK GENERALReplies: 2Last Post: 31st Oct 2010, 10:25 PM -
Cutting Colourbond Sheet.
By STAR in forum METALWORK GENERALReplies: 14Last Post: 11th Aug 2008, 03:50 PM
