Results 1 to 5 of 5
17th Oct 2019, 11:14 PM #1Golden Member
- Dec 2007
- 574
Help identifying indexable inserts
For $5 I bought a 2ltr ice cream container of inserts at the local Sunday morning car boot sale some used and some appear to be unused I recognise a quite a few but others have me stumped with regard to their intended use perhaps someone in the know could enlighten me, here are pics of some of them .
There are trapezoidal shaped ones that are flat on the top - one end has what looks as if it is a small piece of different material has been fixed/silver soldered to the insert, it has a mirror finish polish.
There are others that look to have the same piece of different material fixed to the end - the body is shaped to fit into a parting off/grooving tool holder - the high mirror finish polished cutting tip is radiused
If they are intended for turning some sort of exotic metal then it probably won't be worth buying a tool holder for them.
17th Oct 2019, 11:20 PM #2Most Valued Member
- Jul 2016
- 35
- 1,522
They are almost definitely CBN or cubic boron nitride, used for hard turning extremely hard materials. I'd be interested in purchasing some for sure. I'll send a PM.
They may also be some kind of ceramic but I have never used those.
18th Oct 2019, 09:08 AM #3Most Valued Member
- Mar 2011
- Southern Flinders Ranges
- 1,552
PM me an email address and I can email you the pages from the engineers black book that has all the information on insert identification. I may also be interested in purchasing a few if you are inclined to sell
18th Oct 2019, 05:43 PM #4Diamond Member
- Mar 2014
- South of Adelaide
- 1,227
The boxes with individual inserts are marked PCD which stands for poly crystalline diamond, if the inserts in the box are true to label they are for high speed turning of aluminum. you should be able to look up the part numbers on the box on iscars website or put them into google.
18th Oct 2019, 06:38 PM #5Diamond Member
- Aug 2019
- Revesby - Sydney Australia
- 1,195
I'm just trying to work out inserts myself, but this might help you to identify the shapes;
1) Some common ones:
2) A reference:
Turning Inserts Identification | MITSUBISHI MATERIALS CORPORATION
e.g.
CCMT09T304 = 80°, 7° relief angle, , , 9/9.5mm side, 3.97mm base to cutting edge, 0.4mm corner radius
CNMG120408 = 80°, 0° relief, , 2sided chip breaker, 12/12.7mm side, 4.76mm up, 0.8mm corner
Coated Indexable Inserts For Sale
By Col2310 in forum METALWORK - Machinery, Equipment, MARKETReplies: 1Last Post: 11th Mar 2019, 12:53 PM -
Does Anyone Use Circular Indexable Inserts?
By Anorak Bob in forum METALWORK GENERALReplies: 9Last Post: 20th Jun 2018, 07:12 AM -
Indexable carbide inserts chipping
By familyguy in forum METALWORK GENERALReplies: 12Last Post: 5th Nov 2017, 12:37 PM -
For Andre - Indexable Inserts
By Anorak Bob in forum METALWORK GENERALReplies: 20Last Post: 31st May 2012, 09:18 PM -
Indexable End Mills vs Indexable Face Mills
By Big Shed in forum METALWORK GENERALReplies: 4Last Post: 9th Dec 2010, 11:05 PM
