Results 1 to 2 of 2
Thread: Involute gear cutter thickness
12th Oct 2019, 10:20 PM #1Most Valued Member
- 2,671
I'd never checked but had assumed that involute gear cutters in a set would be the same thickness. Found out tonight they aren't (or at least the M1.5 ones I've got aren't).
Not an issue if you are just cutting one gear, but if you happen to be cutting a couple with different tooth count and need to change the cutter to suit - it will no longer be on center height due to the different thickness.
You need to reset the centre height for each cutter.
Hopefully that saves someone else making the same dumb assumption I did, but if was the only one on planet that didn't already know, then just sleep easy that I do now
13th Oct 2019, 04:21 AM #2Most Valued Member
- 4,890
Things like this would generally fall under assumed knowledge.
Selecting Gear form cutter
By jcatcmc in forum METALWORK GENERALReplies: 11Last Post: 3rd Jul 2019, 10:52 AM -
Source for 20degree pressure angle 10dp involute gear cutters
By caskwarrior in forum METALWORK GENERALReplies: 13Last Post: 29th Mar 2019, 09:01 PM -
Sketchup Involute gear Plugin : Export 3d print file
By steamingbill in forum METALWORK GENERALReplies: 3Last Post: 11th Feb 2016, 09:30 PM -
WHERE CAN I BUY THIS TYPE OF GEAR TOOTH CUTTER
By beefy in forum METALWORK GENERALReplies: 12Last Post: 20th Mar 2015, 04:07 PM -
Gear cutter supplies
By bob ward in forum METALWORK GENERALReplies: 8Last Post: 18th Jul 2013, 12:19 AM
