Results 1 to 9 of 9
Thread: Sony DRO noise common?
12th Oct 2019, 04:37 PM #1Intermediate Member
- Apr 2019
- 25
Hi Fellas,
I have a Sony LG10 DRO on my milling machine, I gather it's a mid 1990's model (two axis DRO). I've only had it a short while (along with the mill) and have hardly used it, but when it's powered up and in use (while the mill is not running) I can hear a high pitched noise coming from the unit, it sounds a bit lower in tone than a mozzie right near your ear
I took the cover of the unit off and had a look in there but there doesn't appear to be any problems or moving parts causing the noise, so is this noise common? If you have one of these DROs does it make a noise? Any help would be tops
12th Oct 2019, 06:56 PM #2Most Valued Member
- 4,258
If its working okay I'd just turn the stereo up louder
12th Oct 2019, 07:45 PM #3Senior Member
- Dec 2010
- Syd
- 492
One of the Eassons here has buzzed virtually since day 1, going on 10 years now. The lone Sony, doesn't make any noise, but the numbers on the display will zero occasionally for no apparent reason....usually at the last stage of a job, must be getting on to 35 year old that one!
12th Oct 2019, 08:30 PM #4
I've repaired a several of those old, 20 years +, DRO units. The electrolytic capacitors dry out with age. The usual suspect ones are in the power supplies and any decoupling capacitors in the display. Changing them usually cures the problem. The capacitance value is very rarely critical, but never fit capacitors with a lower voltage rating.
One that I did buzzed. That turned out to be the transformer laminations ! The transformer had lost its wax over the years. It was mounted on a vertical panel, and a puddle of wax below it on the bottom of the case gave it away. A dose of hot melt glue sorted that one.
Another issue with old electronic devices is dried solder joints. I've had displays with one digit out or missing segments that were down to bad solder joints. Sometimes tapping the circuit board with a pencil brought things back to life.
HTH.Best Regards:
12th Oct 2019, 11:44 PM #5Most Valued Member
The experiences of the Members on here is phenominal. I've not seen a question yet that's not been answered in a plausible way.
Thanks EVERYONE.
15th Oct 2019, 08:24 PM #6Intermediate Member
- Apr 2019
- 25
Thank you Fellas, your replies are most appreciated! I am going to get to use the mill (and therefore the DRO) some more soon, so I'll see how the noise goes and workout what to do from there, turning up the radio or spinning the mill quicker is the cheapest option for sure
16th Oct 2019, 07:47 AM #7Senior Member
- Jun 2012
- melbourne
- 341
If its a switchmode supply you are probably hearing the switching frequency or some harmonic of it. As BaronJ said, capacitors are possible suspects and inductors. A bit more here
https://www.eevblog.com/forum/projec...ng-coil-whine/
Useful idea with the tube but I haven't tried that myself.
I just bought some of this as I am repairing a TV switchmode supply at the moment and most discrete components are held in place with this stuff
https://www.ebay.com.au/itm/New-High...frcectupt=true
16th Oct 2019, 06:21 PM #8Intermediate Member
- Apr 2019
- 25
Thanks Sossity for information. I've used the tubing method before, so I'll try it again on the DRO.
16th Oct 2019, 06:58 PM #9
Be careful with the silicon rubber/bath type ! RTV stuff is very good and doesn’t contain acetic acid (Vinegar) which will attack the components. This is one reason that I prefer to use hot melt glue. Another reason is that its next to impossible to remove cleanly. Where hot glue just melts and runs off with a hot air jet.Best Regards:
common plumbing tap spindle thread ID sought
By desbromilow in forum METALWORK GENERALReplies: 9Last Post: 28th Jan 2017, 10:51 AM -
Changing collet type - obscure to common
By jhovel in forum METALWORK PROJECTSReplies: 5Last Post: 3rd Jul 2016, 12:09 AM -
common sizes for square steel bar
By welder in forum METALWORK GENERALReplies: 5Last Post: 9th Jan 2012, 07:53 PM -
Is a 1-1/2"x16UNF nut common?
By Com_VC in forum METALWORK GENERALReplies: 2Last Post: 15th Feb 2010, 09:58 PM -
Two of the Least Common Hercus Lathes at H&F
By hux in forum METALWORK GENERALReplies: 1Last Post: 27th Jun 2008, 09:31 AM
