Results 1 to 10 of 10
Thread: Brazing Carbide Tips
26th Sep 2019, 10:53 PM #1Golden Member
- Apr 2019
- 589
My current project is to make a 105mm core drill for use with soft sandstone. I have already made the core drill using some steel pipe. I cut material clearance slots in the business end then cut some grooves and slits for teeth. It cuts reasonably well but the steel sure does wear quickly. I lost around 5mm of steel for a 300mm core (and I have ALOT of coring to do).
I have some rectangular carbide blanks that I would like to braze onto the core drill as the carbide should be more resistant than the steel. My plan is to braze them onto the end of the core drill in the material clearance slots. Think of the end of the core drill as being like an old castle wall top (casilated) with the inserts fitting into the gaps. The core drill is around 2mm thick and the carbide tips around 4mm thick, 12mm long and 6mm wide. I would like the carbide tips to overhang the core drill by 1mm inside diameter and outside diameter.
My question is, if the carbide blanks fit reasonably tightly into the 'slot' in the core drill (I believe 3 to 5 thou " is required) will there be enough surface area to make a strong bond?
I believe there is a technique called braze welding which does not rely on the capillary action but fills the edges/fillets more like a MIG/TIG weld. Would this be better?
Also, what tip would be needed on teh oxy torch? A welding tip? Size?
27th Sep 2019, 12:41 AM #2China
- Dec 2005
- South Australia
- 1,656
Carbide tips are normally brazed with bronze brazing rod, or silver Solder/brazing rod, capillary action is a desired result, stronger bond, I would not attempt it
with out Oxy/acetylene, tip size at a guess no. 7 You will then need to to flood the cut with water while drilling, otherwise the core drill will become too hot and the tips will part company with the body
27th Sep 2019, 01:03 AM #3Senior Member
- Nov 2010
- Frankston south
- 102
just buy one, a lot less heartache
27th Sep 2019, 02:30 AM #4
Hi Mk1_Oz, Guys,
Yes a four inch (100 mm) core drill is a standard hole size. Here in the UK you can get one complete with a mandrel for less than £10. ($20 at the current exchange rate).
100mm Core bit.jpgBest Regards:
27th Sep 2019, 10:45 AM #5Most Valued Member
- Jun 2012
- SA
- 1,649
Capillary action should get into the join OK. Be aware that the strongest braze joint has the smallest filler thickness - bronze braze gets weaker as the filler gets thicker. So less is better.
Any brazing tip for oxy/acet or oxy/lpg should do it, but use a small flame pattern for more control.
You may be able to go nickel bronze brazing rod (the strongest medium), but I've never used it and can't comment on it's suitability for carbide.
Cheers RobThe worst that can happen is you will fail.
But at least you tried.
27th Sep 2019, 05:02 PM #6Golden Member
- Apr 2019
- 589
I will be using oxy-acetylene (another learning adventure!). To buy a core drill bit is AUD$300 for a 120x450 diamond coveted bit with a 1 1/4 UNC thread. I have been told by several sources that the diamond bits are not good for soft materials as they will wear extremely fast. Counter intuitive but seems to be true.
I will silver solder or bronze braze a get the joints nice and tight.
27th Sep 2019, 07:06 PM #7Most Valued Member
- Jun 2012
- SA
- 1,649
As you are using oxy/acetylene there is no point in going silver solder. The high silver content rods you will need for the steel base are very expensive and the bond will be weaker than manganese bronze.
So go to BOC and get some decent Profill uncoated rods and some Eziweld 303 dipping flux.
That way you can apply just the amount of flux you want to prepare the join and be in control of the whole operation.
Don't buy unbranded brazing rods from tool supply companies as they flow poorly, are usually coated, and are basically garbage in comparison to BOC offerings.
Plumbing suppliers also generally sell good quality uncoated manganese brazing rods (possibly BOC) - if you want to buy them singularly.
27th Sep 2019, 11:51 PM #8Senior Member
- Nov 2010
- Frankston south
- 102
Whilst what you have been told is partly true............Green concrete or softer materials require a harder bond to slow the wearing process. You are only coring Sandstone type material. $75 buys a 102mm core on ebay and they work ok, if you want you can spend $500 but I wouldn't, and I do this for a living
28th Sep 2019, 12:49 AM #9Golden Member
- Apr 2019
- 589
28th Sep 2019, 01:30 AM #10Senior Member
- Nov 2010
- Frankston south
- 102
Brazing Carbide
By Tiger in forum WELDINGReplies: 4Last Post: 6th May 2010, 11:43 PM -
Tungsten Carbide tips
By Godzilla98 in forum THE HERCUS AREAReplies: 1Last Post: 30th Jan 2010, 03:12 PM -
How to tell when carbide tips need replacing
By 19brendan81 in forum METALWORK GENERALReplies: 4Last Post: 16th Nov 2009, 08:50 PM -
Carbide Tips for Screwcutting
By electrosteam in forum METALWORK GENERALReplies: 4Last Post: 11th Oct 2009, 09:30 PM -
Resharpen carbide tips?
By neksmerj in forum METALWORK GENERALReplies: 6Last Post: 16th Sep 2007, 11:04 PM
