Results 16 to 24 of 24
Thread: Brass blocks need help to find
30th Sep 2019, 09:50 AM #16Most Valued Member
- 4,258
I was just about to start the search for this size also starting with Surmans in Adelaide then George White ...
now I have Edcon thanks guys
but I did also have a plan B.....ask one of our foundry members to cast me a block...i can supply the scrap brass
2nd Oct 2019, 09:22 AM #17Most Valued Member
- 4,258
alternative I just thought of.... stainless steel?
it is the steam chest and brass was used to combat corrosion i guess....so in theory we should be able to use s/s
or even steel providing we keep it lubricated?...couple squirts of oil every time we fire it up with aircompressor?
Surmans in Adelaide was $71.50 for a 200L x 52x52 hunk of brass
2nd Oct 2019, 08:41 PM #18Senior Member
- Feb 2009
- jilliby nsw
- 111
Hi Eskimo, SS would be an alternative for sure, however I've previously found that SS (316 which I machine a lot of) is quite a hard material to machine so the hand finishing of parts, I'd expect, would be a difficult task particularly if the model was to be a bit of a "show piece". The other components that attach to the body are also a little complicated with all the slots, steam passages etc. that require quite small drills and end mills, which I've found by previous experience have a high tooling mortality rate. I think I'll stick to the plan re: Brass cause it polishes well and is easy to machine. The steel would be OK too but things rust where I am so the whole engine would need to be an oil/grease ball to protect the external surfaces. PS I plan to spray the finished components with a clear coating process to combat oxidation and corrosion.
3rd Oct 2019, 10:23 AM #19Most Valued Member
- 4,258
I will be painting mine
oh and I will let you get in front of my build ( not that I am slow or anything like that) but just so you can tell me of any other errors you find along the away.
3rd Oct 2019, 07:33 PM #20Senior Member
- Feb 2009
- jilliby nsw
- 111
Noted Eskimo
14th Oct 2019, 10:12 AM #21Most Valued Member
- 4,258
spotted another error with the drawings...i think
the centre to centre of the two piston conrod journals is 60.4 ....if using the crankshaft measurements of the crank shaft drawing..ie 7.5+7.5+8+8+29.4=60.4
yet the centres of the two cylinders is shown as 66.3 on the drawing of the brass body and cylinders.
14th Oct 2019, 04:45 PM #22Senior Member
- Feb 2009
- jilliby nsw
- 111
14th Oct 2019, 07:21 PM #23Most Valued Member
- 4,258
15th Oct 2019, 09:28 AM #24Most Valued Member
- 4,258
yes you are right hpa1
The latest drawings that Stewart sent me has been changed from 29.4 to 35.3
old pic
thanks for that I will destroy those in shed and work off the latest.
But beware of other errors hpa1
edit. just checked what I put up in other post and that file is a copy of the one Stewart sent me. I will destroy the old file.
what rods for thin brass to brass ??
By Mathuranatha in forum WELDINGReplies: 7Last Post: 23rd Nov 2020, 08:17 PM -
Jo Blocks
By YBAF in forum METALWORK GENERALReplies: 6Last Post: 12th Feb 2016, 01:07 PM -
How can I touch up V blocks?
By Michael G in forum METALWORK GENERALReplies: 23Last Post: 8th Oct 2014, 10:04 PM -
VICTORIA Brass Flat Bar Assorted Sizes & 1/4" SWB Threaded Rod & 260 Carbide Brass Sheet
By thumbsucker in forum METALWORK - Machinery, Equipment, MARKETReplies: 7Last Post: 18th Mar 2013, 03:36 PM -
Gauge blocks
By morrisman in forum METALWORK GENERALReplies: 9Last Post: 23rd Dec 2012, 11:44 AM
