Results 1 to 12 of 12
Thread: Change Gears
17th Sep 2019, 11:34 AM #1Novice
- Oct 2018
- Dandenong
- 13
Change Gears
Can anyone tell me if there is anywhere in the land down under to get gears
for a Mk1 Colchester Bantam Lathe.
I have had one quote from the UK, but at $250+ I thought a bit of searching
was needed.
Cheers Robb41
17th Sep 2019, 12:55 PM #2Member
- Nov 2009
- australia
Sometimes you just have to swallow a '$#it sandwich' and pay the asking price ---------
17th Sep 2019, 12:58 PM #3Most Valued Member
- 4,890
Did you try RDG?
17th Sep 2019, 01:45 PM #4Novice
- Oct 2018
- Dandenong
- 13
17th Sep 2019, 01:47 PM #5Novice
- Oct 2018
- Dandenong
- 13
17th Sep 2019, 02:35 PM #6Most Valued Member
- Oct 2010
- melbourne, laverton
- 1,910
17th Sep 2019, 04:06 PM #7Novice
- Oct 2018
- Dandenong
- 13
17th Sep 2019, 09:01 PM #8Golden Member
- Oct 2001
- ACT
- 667
Aaron, you have any six tooth spline gears?
21st Sep 2019, 07:42 PM #9Most Valued Member
- Oct 2010
- 1,910
colchester gears
An 18 tooth. um ok have you tried ebay uk.
Or face book groups?
how about machining down a 8 tooth spline gear to a blank.
Using that to cut the gear?
got any photos of your bantam. and your change gear set up.
id love to see that.
Steve. definitely may have 6 change gears that are 6 tooth drive splines.
I have to find them.
Is that how there there described.
Steve what would you like? what are they for?
I have at lest a dozen gears that i believe are for colchester lathes
8 tooth drive spine. between 36 and 90 tooth.
ive got a master 1 1/2 i think.
these gears where a separate thing i came apone....
aaron
23rd Sep 2019, 01:58 PM #10Novice
- Oct 2018
- Dandenong
- 13
23rd Sep 2019, 03:31 PM #11Senior Member
- Aug 2012
- Greenmount, W.A.
- 70
- 275
I have started making a 127 tooth gear for my mates Bantam and my Harrison M250, which is the same beast really. I purchased some 100 tooth gears while in the UK last year (for the translation set) and brought them home with me, but I don't think I will be using them all, so there is one spare. I have purchased a set of involute cutters to make the gears. I suggest you do the same. The spline on the gear can be cut with a shaper. Hope this helps.
Regards,
Alan.
23rd Sep 2019, 08:13 PM #12Golden Member
- Oct 2001
- ACT
- 667
my chipmaster has the 6 tooth spline.
what tooth sizes do you have?
Hercus Change Gears
By pipeclay in forum METALWORK - Machinery, Equipment, MARKETReplies: 3Last Post: 30th Dec 2018, 02:51 PM -
Change Gears Required.
By colnjulia in forum WANTED TO BUYReplies: 0Last Post: 21st Sep 2018, 02:10 PM -
A novel way of creating change gears
By Michael G in forum METALWORK GENERALReplies: 7Last Post: 25th Jul 2013, 09:41 PM -
Change Gears Again
By Bryan in forum METALWORK GENERALReplies: 47Last Post: 24th Jan 2011, 10:14 PM -
Change Gears
By pipeclay in forum THE HERCUS AREAReplies: 0Last Post: 8th Oct 2009, 02:54 PM
