Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Thread: Reamers
    Nov 2011
    102
    Default Reamers
    After any recommendations for a 8 mm reamer?
    To ream a mild steel bush approximately 15 mm deep.
    Having never ever done this I’m open to guidance
    Do I go cheap from EBay China ?
    A spiral ream,hand or machine driven(lathe Hercus 9 inch).
    I’m wanting to make a small wood work marking gauge.
    Using an 8 mm harden ground shaft.
    Cheers Matt
    6,477
    Hi Matt,
    All my reamers are cheap Chinese ones.
    I made a marking out gauge some time ago. I used a carbide stylus in mine. Would be interested to see yours.
    Nov 2011
    102
    Hi Matt,
    Thanks Baron,
    That’s good to know, I might grap a cheap one to start with, an see how I go.
    My gauge will be another long term project, don’t we all have them.
    As unfortunately my circumstances have changed a bit so shed time will be limited for a bit.
    But there’s always planning an window shopping to be had.
    Cheers Matt.
    Feb 2013
    Laidley, SE Qld
    1,039
    ebay China, aliexpress etc will be OK
    A straight flute reamer will be fine for the simple reaming job you want to do now, a spiral flute reamer is more versatile, plenty of reading on the interweb.
    Machine reaming is always going to be more consistent than hand reaming.
    Nov 2011
    102
    Quote Originally Posted by bob ward View Post
    Thanks Bob,
    I did do a little bit of research the other day,
    But I have a lot more faith in the information I get here.
    Cheers Matt
    Nov 2009
    australia
    57
    Go for any that you can afford, if you decide to use the lathe, then make sure you are only taking out/cutting with the reamer, just the last few thous.
    Bore it as close as you can and just use the reamer to be sure of the exact size hole your after.
    One thing you should NEVER do with a reamer, is use reverse on the lathe chuck to take the reamer out, just leave the lathe in forward and gently remove/draw back the tail-stock by hand.
    Reason is - if you reverse the chuck whilst the reamer is still in the job, then you surely can and at some time will, take the cutting edges of the reamer.
    Same when using a reamer by hand, never twist it backwards to the cutting edges.
    If you never twist it backwards then the reamer will be as sharp as for ages.
    Never store them loose in a draw and allow them to bump each other or anything else that's hard, think of chips being taken out of the cutting edges.
    Oct 2011
    Norwood-ish, Adelaide
    59
    6,561
    I've bought several reamers second hand from ebay. Reamers are not the sort of tool that the average handyman picks up so are likely to be in reasonable condition, even if a little grubby and not quite as sharp as they could be. If this is just a one off, then that may be a way to go (I might even have a 8mm that you can borrow, but then there is postage...).
    Nov 2011
    102
    Thanks for all the advice so far everyone.
    I definitely won’t be running the cutting edges backwards an will keep them on the shelf in the little plastic boxes.
    Michael thank you for the offer, but I’m now waiting on one from eBay.
    Which would probably be the same as postage in Oz anyway lol.
    Cheers Matt
    Jun 2007
    Vic
    48
    544
    Hi Matt,
    I have one and I am in Mt Waverley if you need to borrow it.
    Regards,
    Trong
    Nov 2011
    102
    Quote Originally Posted by jackaroo View Post
    Hi Matt,
    Regards,
    Trong
    Trong,
    Thank you very much for the offer, I may have taken you up on that,as I’m in Glen Waverley during the week.
    (High Street Black burn road)
    But I’m waiting on some to arrive from eBay.
    Cheers Matt.
    Jun 2007
    Vic
    48
    544
    check your inbox Matt...
    Feb 2020
    55
    Default To Buy or Not To Buy?
    This thread has been useful, in that it seems that even cheap reamers will an ok job in a home workshop.
    Even this cheap though?
    https://www.ebay.com.au/itm/15-Pcs-S...53.m1438.l2649
    Does anyone have any experience with cheapies like this from ebay etc??
    Oct 2004
    Southern Highlands NSW
    1,898
    Very much agree.
    Hand reaming might work, but in my experience is that it's easy to get a "rounded polygon" shaped hole, not necessarily noticeable.
    Nov 2017
    Geelong, Australia
    57
    2,672
    Quote Originally Posted by Fast Freddie View Post
    Adjustable reamers are great for the occasion where you're stuck without a particular size or when you need to take a smidgeon out of a bush that has shrunk when installed after you got the fit wrong, but apart from that I never use them. I've got a set that came from my grandfather - I think I've used them maybe 3 times in the last 15 years or so...
    Also only good for through holes due to the adjustment nut.
    IMO - if you've already got fixed size reamers then by all means grab a set of those to have on hand to get you out of trouble, but otherwise just pick up some cheap fixed size ones. I got a cheap set recently (possibly from Banggood) that I think were only about $20 for the main sizes from 3-12mm.
  15. #15
    6,477
    Hi Freddie,
    I have and use adjustable reamers ! But they have one major downside, the fact that they can be adjusted means that you have to be careful only to alter them in very tiny amounts or they will grab and the blades will break. All the normal rules apply ! And like other cutting tools used inside bores, plenty of cutting compound, tapping compound like Temaxol and the like works well, just plain oil will do if you don't have anything else
  1. Reamers
    Last Post: 15th Mar 2018, 10:36 PM
  2. Reamers 101
    Last Post: 4th Apr 2014, 12:51 AM
  3. reamers
    Last Post: 27th Oct 2011, 10:42 PM
  4. where to get reamers etc.
    By holmsy2000 in forum METALWORK GENERAL
    Last Post: 16th Nov 2006, 02:23 AM
